Official random 928 Picture Thread (post a new 928 pic or stay out)
#7816
Custom arms allow for extra camber, over 4 degrees is possible.
The lightweight shocks are adjustable and save quite a lot of weight.
The discs are 355 MM two piece Brembo items.
#7817
Swirl-free finish!
#7819
Before
After
#7821
The arms don't provide extra caster as far as I am aware, The dampers are Leda, this company was based in the UK and went into liquidation a few years ago however there is repairers who still service the dampers in the UK although I am pretty sure a specialist could probably do it locally if required. The save around 10 pounds per corner. The front springs are 600 pound and the rear 250 pounds. Contrary to popular belief the rear rate shouldn't be as high as 400 which is often used.
Above, the F50 Brakes fitted.
Below the rear brakes are 993 twin turbo which I believe were the first ever fitted to a 928 back in 2001.
The proposed brakes for the track car
The callipers are just in a mock up but the disc will be a PFC item 350 mm in diameter. The rear are the 997 twin turbo callipers. PFC specialise in cast iron and the general consensus is they are the best disc in this category being both lighter and more stable in temperature. The also use the V2 mounting system
#7823
Archive Gatekeeper
Whoa whoa whoa- Greg, I presume your car is RHD? Is this portal just for clutch master work? Looks like many interesting shiny bits that I don't recognize, inside....
#7824
Archive Gatekeeper
{facepalm} Thanks Erkka, didn't think about the Euro reflector and the fact that I was looking at the left side of the car, not the right..... {/facepalm}
#7827
#7830
Archive Gatekeeper
Renix-
Digging the engine lift bar you have there, is that a factory 9137 tool?
1986 Brochure Exterior paint palette (click picture to open full size):
