Test drove a GTS
Brian,
Was the exterior color close? Is it a 5 speed? I don't know of any listed Amazon green with black interiors. I believe I have one of the few if not the only Amazon/cashmere GTS and all the others appear to be gray interior.
If it is Amazon I would be interested in seeing pictures of the car with the black interior. If it is not Amazon do you have any idea what color it is?
BTW Amazon is a great color and I am not a green fan. It looks more blue and black than green.
BTW most Boxster owners act that way to all Porsche's. I for one do not care for the Boxster even the S is lacking. IMO ALthough it is funny to see their faces when you dust them in an old 928.
Originally Posted by cobalt
Brian,
The car needed washing badly. Outdoors (under the dirt) it appeared metallic black. Once I pulled it into the shop it was apparent it's green. Like I said, it was advertised as black, so it's not just my eyes failing me.
Originally Posted by Red1
Auto trans.
Here are some pictures of Amazon green in different light
a boxster S got right behind me, then passed .
Thats your biggest problem.
Get the ppi, have them look at the gas pedal and if everything is ok low ball the price. The guy must want to get rid of it, if he hasn't taken care of it. All the seals around my doors are factory fresh and its 8 years older. Can't imagine what is wrong with the gas pedal. Its a simple mechanism in that it pulls directly on the butterfly.
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
We all deal with our cars and purchases differently. I am not dissing anyones car or maintenance habits. I AM however, offering my suggestions based on my personal experience to Red1. Again, what is a major item and what isn't? Uhmm, I think tires are major...look at the wear pattern. And throttle, I think I would be very concerned. Stiff throttles can turn into stuck throttles just for example.
Things tend to get very expensive on a GTS. If it is anything "less than", I would be VERY cautious. JMHO
On S4 and later models gas linkage is more complex than in 16V engines. There are several places where it can bind. Not very common to have problems in it but possible. Can be very simple to fix or need intake removal.
JMHO
A stuck throttle is my concern. Having experienced that once in life, I have no desire to do that again.
Good luck hope all works out in the end. Meatllic black with black interior sounds like a nice rare combo. Seals can be replaced and problems fixed. If the price is right go for it.
Complex linkage junction attached to left side of intake has six small bearings on those moving levers. If these are bad that is one point which can be problem besides obvious places like where cable comes out of shield. Under intake there is open piece of cable which goes around roller. Then there is throttle body itself.
There is also the possibility of moisture having gotten to the flappy bearing (under that rubber plug on top of the intake) If this bearing is trashed, then although an easy fix, a small PITA. With me, If I am going that far, lot's of things come off the engine then and it's rrrrrrrrrrrrrreeeeeeeeeeFURBISHING time with powdercoating....
Sharkaholic
And fuel line maintenance is more important to me then oil changes and spark plugs. But almost everyone is diligent in changing the oil, and putting new plugs, caps, rotors, and wires on their cars. Having been bitten by the old OH **** my car is on FIRE! I tend to spend my money on fuel lines.
But hey my hatch don't work, half my interior lights are in-op, but by god I got some nice new fuel lines in there!!
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Thanks for the laugh. I'm all too familiar with the "while-I'm-in-there" virus.
