I must be blind, where is the dipstick?
Glasses broke and I can't find sh&%!
928 Int. is out of '83 Owners Manuals and I want to change the oil. But I can't find anything !
I also need to replace a sunroof switch, any tips?
Thanks alot!
Thanks alot!
https://www.928gt.com/p-2105-83-owners-manual.aspx
http://www.mailordercentral.com/928i...KD%20471%20821
That's all of the help I can offer, my 928 still hasn't come in yet.
First a little adwise
. Allways keep spare pair of glasses
I do ! .Stick is rightside, front of engine between engine and belt's, mine is yellow in the top. Sunroof switch is prob. like window switch - take of side panel ( the carpet part ) of center consol 2 or 3 screews, right or left side depending witch way the cable goes around the gearstick, my guess would be right side ! Switch cable lengt is aprox 20 inch and you should find and connector, disconnect old...connect new. Should be pretty easy......
The dip stick is tight to the right side of the front cam belt covers ( your left when facing the car), tucked in admidst the v-belts: An '83 may have a wire loop top vs. the higher tech yellow top of later models
Do NOT use 10W-30 motor oil ... go with a 5W-40 to a 15W-50 ( it's the 40 or 50 that is important vs the 30 weight).
I use 20W-50 in both of mine except in the winter. It takes 7.6 quarts of Oil when changing with filter. Then check after running and see if you need more , should be between the top two marks on the dip stick. Good luck with your new purchase. ( it is normal to use some oil ).
Originally Posted by Randy V
Let us know when you've found the dip stick for the auto tranny fluid... ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Whomever is lucky enough to find that is the one to send out for a dozen skyhooks and a gallon of striped paint ...
On my car the dipstick is usually standing in front of the engine trying to get the long wiggly thingy in the oil level testing hole place down there in the dark.
