Flat plane a 928 engine?
1. The crank is about 10 pounds lighter than an equivalent 90* crank. That will give you about 50 more whp in first gear due to not consuming engine power by extra inertia.
2. The firing order allows better exhaust scavenging because cylinders can be paired that are 180* out of phase.
Sound is a function of displacement, tube size/length, rpm, cam timing, and compression ratio.
One can create a close to the same high rpm sound with headers and exhaust.
One can make more power with the 928 engine in so many different ways that are way more cost effective.
If you were in a five liter otherwise unrestricted racing class, the maybe. But even then, the first $500k could be spent with a higher return.
But that's besides the point. There no need for anything we do to be logical. Because I can is perfectly sufficient reason.
I think you are way over on the HP "savings" due to the relatively small diameter of a crankshaft ..... I know light weight crankshafts are popular and some are gun drilled too to hollow out the centers which is the least efficient way to reduce the inertia as it is the centerline of the mass...
[QUOTE=James Bailey;12116246]
Yes taking it to the absurd is but one way to test a theory...
I think we need to go over the inertial mass vs HP discussion.
if you remove weight from the crank, pistons, flywheel, driveline, etc, the HP effect changes in what gear you are in.
4lbs off the flywheel (if the weight is distributed 9" evenly) is like 26hp in 1st gear, 15hp in 2nd, 5hp in 3rd, 1.5hp in 4th and less than 1hp in 5th. (for example)
Now, we are making an assumption of a 10:1 power to weight ratio. 3000lbs / 300hp for example... however i can equate the hp savings to a weight savings, and then you can calcuate it from there.
so that 4lbs is like removing 260lbs out of the car n 1st gear
150lbs in 2nd, 50lbs in 3rd, 15lbs in 4th and less than 10lbs in 5th.
