Non-LSD to LSD or PSD
ok well so much for quaiffe
Bill what i meant by carrier, is the part that the ring gear bolts onto, ususally its an open diff with spider gears or some type or lsd or locker or whatever. I could be wrong in calling that a "carrier" but what i meant was the part that the ring gear bolts onto, it looks like......a short coffee can with a dome on itt with the spider gears. hell i dont know how to describe it
Under the Lift
OK, well I call that the differential...but I see what you mean - the standard diff is a collection of gears and shaft parts, but the LSD comes as a assembly that looks like a coffee can.
if you want to know what insiders in the manufacturing world call it is the differential case. The housing that holds all the parts (and oil) is the differential carrier. I have spent the better part of 15 years in the automotive parts manufacturing indusry. A lot of that in drivetrain.
Originally Posted by Bill Ball
Otherwise, it a straight enchange of the open diff for the LSD, using your existing ring gear and shimming the new unit for fit and backlash.
Under the Lift
Originally Posted by bd0nalds0n
I thought that the ring and pinion gears were matched pairs? Don't you potentially introduce some problems by swapping one but not the other?
Quaife were going to have a look at a diff for me, there is quiet a bit of commonality between the G50 gearbox and the 928. They said 5 diffs if custom was a minimum and if the mods were minimal they would look at doing them for 750 pounds each. If the mods weren't minimal the cost would be double.
Cheers Greg
Cheers Greg
Under the Lift
Hey, this is good news. Keep us posted. I'm sure you can get a pretty good order from here....what's the currency exhange rate for that 750 pounds?
About the Quaife , as I recall 10-15 years ago they wanted minimum ten units and maybe $2,500 each now .."if the mods were minimal they would look at doing them for 750 pounds each. If the mods weren't minimal the cost would be double. " with exchange rate at 1.894 dollars some $1,500 to $3,000. Mark Anderson has converted to a normal limited slip in his GTS gear box, the tricking of the PSD with a bolt tended to cause understeer in slow corners as well as the amount of lock-up seemed to change with heat.
