Murf928 G-Tech run 11.49sec @ 132.59 mph 3.79sec 0-60
#32
Supercharged
Here's a scan of the company you're keeping from the latest Road & Track.
In my brief scan it looks like the Enzo, Panoz, CGT, and the 911 GT1 are the only ones that beat it. THe cheapest of which is $455k!
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
#33
Range Master
Pepsie Lite
Pepsie Lite
Pleased, but not even emotely surprised...........
Woo!
Woo!
#34
Originally Posted by Andrew Olson
...until something breaks. ![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
#35
Originally Posted by pmotts
Any idea how much boost? This is a stock internal motor, right?
The motor is virtually a stock motor with the pistons dished out to lower the compression to 8.6:1 There are a lot of other small modifications but that list would get a little tedious to try and lay out here.
I have the JDS Shark Tuner and really need to get it on the car for some testing. I'm sure I have way too much timing advance upstairs which is certainly not helping me.
#38
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Originally Posted by Tim Murphy
I'm not exactly sure on the boost. There is NO WAY you can look at the boost gauge under full throttle but I would estimate I am around 15-16 psi.
#40
Supercharged
OMG!!! Tim just sent me his G-tech file! ![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
Here's his run -vs- my best run which I took to 143. Look at the 0-130 times! He's almost 5 full seconds faster! I can't even imagine what that must be like! Super job, Murph! But I think you could do better. Looking at the RPM scale, you didn't even rev it to 2.5k rpms on launch. That's good for about 0.2 of a second right there (but may also cause things to break...)
#42
He is also shifting, at, ahem, 7k rpm. Because its still, um, pulling up there. Like a fighter jet pulling off an aircraft carrier.
#43
I won't be doing too many more of these runs any time soon. The car does not feel safe accelerating as hard as it does. The drag radials are a little taller than stock, which is what the ride height is set for. Scrubbing off the speed at the end of a run gets pretty squirrelly.
For those that said they would love to get a ride in this thing you might want to think twice about that. There is not one person that I have given a ride that was comfortable sitting in the passenger seat. About 5000 rpm in 3rd is when the screaming usually starts.
#44
I bounced the rev limiter in 1st, 2nd, and 3rd. Just one bounce in each gear.
I'd go, as long as its on 172 or 57, and not, like, down one o f the back roads in Alluez.
#45
Supercharged
I'd go. And yes, I'd feel like my bung was welded shut, and I might even put my foot through the firewall, but then... that's why i want a ride! ADRENALIN!
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
