New Wheels
Originally Posted by BIMMERMIKE
Art_Z, have you lowered your car?
my wheels are the 19" Carrera Classics. 295/30 rear 235/35 front.
19" 's sweet !
Do you have the Boges reds?
Originally Posted by Champagne
Hey Michael,
this wheel is fast becoming the new standard for the 928. I just bought the exact same set.
Did you have any problems with the caps in front?
I'm not crazy about the size of the rear tires. A better choice would be:
265/35-18
But the absolute best (if it clears the fender lip) would be: 285/30-18
These are hard to find though. only -0.5% circumference difference from orignal.
Congrats on the new wheels. They do look excellent
Paul
265/35-18
Paul
I thought the same thing with the 265/40 (26.3") tires vs the 24.7" stock rear tires.......I've found that the speedo-odo really isn't off all that bad......with these exact same wheels I've gone through roadside radar traps usually within 1mph of what the speedo reads.....I guess the factory speedo was a touch optimistic?
Of course the 285/30 is the best & I do think it would fit without rolling....it would be close.....but should fit?
I put them on my 85 a couple of months ago too, fit like a glove. Like Paul said the tire size is not the best and the 285/30-18 is perfect. When the Conti's wear out I plan on replacing with BF Goodrich gForce T/A KDW2, they are available in 285/30-18. They look good with the colored crest caps!
Originally Posted by Bret928
I just purchased the same style wheels. Only mine are 225/40x18s with a 55mm offset up front & 265/35x18s with a 65mm offset in the rear. Huge change to the vehicle. I’ll post some pictures later.
Ft: 18 x 8 1/2", offset of 52: 225/40 ZR18
RR: 18 x 10", offset of 65: 265/35 ZR18
The rears appears to fit fine and it looks like I can keep the spacers on the rear, but the fronts look like they may be sticking out too far. They were a good deal, so I bought them anyway thinking if the front offset is not going to work, that I can always sell the fronts and buy the two front wheels with the correct offset, or go with a 8" front wheel instead of the 8.5" wheel.
Originally Posted by woodsrider
I'd love to see some pics of that setup as I just bought some Turbo Twist "look" wheels. Sizes are:
Most everyone likes them but have suggested that I use some spacers to push the rear wheels out more. I'm taking that under advisement but for now I'm pretty happy.
Besides the style - the only thing different between your setup & mine is the front offset. Yours is 52mm & mine is 55mm.
I posted some pics of my setup in another thread "Bret's Shark gets new Kicks"
For your rear setup, mine were definitely pushed out more towards the edge and really filled up the wheel well, must be due to the spacers that I have on the rear. Personally, I don't think your setup needs the spacers, I think it looks great just the way it is, but on the other hand, if you want the wheels more out towards the edge, the spacers will get you there.
What size spacers did you use? Didn't you say you already had the spacers before going with the wheels?
And I'm not sure the exact size on them, but just eye balling them, they appear to be between 3/4 - 1" thick.
When I get out there this weekend to fit everything I'll take an actual measurement and report back. That is, if some knowledgeable lister does not post the actual thickness before I get a chance to report back.
Ok, update, I'm guessing the spacers on my '85 are 21 mm based on the fact that 928 Specialists lists a "S" spacer of 21 mm which equals approx 0.83 inch. That sounds about right from what I could tell of mine when I eyeballed it yesterday.
https://www.928gt.com/ps-2141-146-wheel-spacers.aspx
