928 Forum 1978-1995
Sponsored by: 928 Specialists
WP bolt lengths
Old Jul 26, 2006 | 04:51 PM
Loaded's Avatar
Loaded
Default WP bolt lengths
OK my bolts are not in the right holes from the removal.......I screwed up
never the less which holes are for the long bolts and which are for the short bolts!
Old Jul 26, 2006 | 05:00 PM
Richard S's Avatar
Richard S
short bolts go in the holes that are lower down on the face of the water pump. For example, the holes along the edge of the wp are slightly raised in comparison with some of the holes further in on the wp. make sense?
Rich
Old Jul 26, 2006 | 05:01 PM
milwaukeeshark's Avatar
milwaukeeshark
Hopefully this will do the job.
Old Jul 26, 2006 | 05:05 PM
Bill Ball's Avatar
Bill Ball
Under the Lift
If you get the bolts in the correct holes, the exposed shanks under the WP are the same length.
Old Jul 26, 2006 | 05:06 PM
Rob Edwards's Avatar
Rob Edwards
Archive Gatekeeper
I'm sure someone's got a better answer/diagram, but from this $13 assembly of fasterners, the 8 yellow cad bolts go around the periphery of the pump, and the 5 unplated bolts go in holes around the neck of the impeller shaft. Of course, the two machine screws are for the timing pointer, and the short plated bolt and hex bolt are for the tensioner-to-waterpump bracket and the end of the tensioner arm, respectively.
I know that 8+5 only add up to 13, and that that many descriptions of the WP bolts list 14 bolts. I may very well be missing one, but 13 got the job done on my '90 which hasn't leaked coolant in nearly 300 miles of driving YMMV.
EDIT: I was right, MilwaukeeShark's got the better diagram. That's great!
EDIT #2- disregard my comments about 13 vs 14. Clearly it was 14, and I was short one bolt in my kit. Must have ended up reusing one bolt.....
File Type: jpg
Old Jul 26, 2006 | 05:13 PM
Loaded's Avatar
Loaded
You animals are absolutely awesome! thanks!
Old Jul 27, 2006 | 03:23 AM
dr bob's Avatar
dr bob
Chronic Tool Dropper
The "missing" bolt #14 holds the timing belt cover on. About 2.5" long, passes through a sleeve that's in the middle of the cover.
