928 Forum 1978-1995
Sponsored by: 928 Specialists
Has anyone seen an oil pump do this? Seized pump - internally broke apart.
Old 07-13-2006, 01:15 PM
  #31
Imo000
Captain Obvious
Super User
Imo000's Avatar
Originally Posted by Hacker-Pschorr
Ok, so as long as the "new" pump matches the design of the old pump I sould be good to go. So there is there a casting number on the pump?
Cool - good to know.
How about this theory: Maybe the shaft seal / bearing was going bad allowing the gear/impeller (whatever that thing is called) to wobble and hit that little bridge piece - eventually breaking a chunk off and taking it with it?
Yup, that is a possibilty. Is there any play in the bearing?
Imo000 is offline
Old 07-13-2006, 01:25 PM
  #32
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,204 Likes on 1,243 Posts
I took out some of my frustration using my vice and a hammer to take the pump apart - so kinda hard to check that now.
hacker-pschorr is offline
Old 07-13-2006, 02:40 PM
  #33
BC
BC's Avatar
I say build the S4 motor. Its just about as much work. And you have other 928s anyway.
BC is offline
Old 07-13-2006, 02:54 PM
  #34
928SS
Road Warrior
928SS's Avatar
bummer!!!
iirc, porsche switched to an aluminum pump gearset then back to steel later. I suspect there was a reason.... so I put steel in mine, figured the weight diff wasn't worth the headache.
guess I might try spinning the pump to build up some oil pressure before starting it or turning it over - if it's dry now, you could spin a bearing and/or grind up more stuff - if it hasn't yet.
928SS is offline
Old 07-13-2006, 02:55 PM
  #35
Jim bailey - 928 International
Jim bailey - 928 International's Avatar
Brendan all he needs to do is put in an oil pump ...throw on a belt and GO ! The bearings should be fine it is an old 16 valve so no bent valves odds are it will be running and driving by Saturday night !
Jim bailey - 928 International is offline
Old 07-13-2006, 03:22 PM
  #36
BC
BC's Avatar
True.
BC is offline
Old 07-13-2006, 08:37 PM
  #37
John Welch
John Welch's Avatar
then used a 90 degree drill & 15mm (I think) socket on the oil pump -
I hope this didn't have anything to do with it...
John Welch is offline
Old 07-13-2006, 08:44 PM
  #38
hacker-pschorr
If it did then it took a very long time to surface
Otherwise, please explain how this could damange anything - I'm all ears. When I did my head gaskets (last year) I was worried about the engine being dry, so I added 8 quarts and spun the gear. The RPM of the drill on the pump isn't even idle speed. There is no way this drill over tightened the bolt holding on the pump gear. It is an interesting thought though, something to ponder before I do it again.
Old 07-13-2006, 09:02 PM
  #39
Herr-Kuhn
Herr-Kuhn's Avatar
Slap it back together and turn the key....just pull the coil and watch the pressur egauge first pass around. I've watched people forget to put oil in cars at repair shops and turn the key only to hear the clatter and then shut down and fill...the customer never knew...
Herr-Kuhn is offline
Old 05-19-2010, 12:07 AM
  #40
ptuomov
ptuomov's Avatar
Default Is there consensus of what caused this damage?
Sorry to bring back bad memories, but is there any consensus on the underlying cause of this damage:
ptuomov is offline
Old 05-19-2010, 01:36 AM
  #41
jon928se
jon928se's Avatar
Read all the way through this before I realised it's 4 years old. However in the photo Tuomo re-posted it's clear that the missing piece is at about 09:30. And that the pump siezed within approx 1/4 of a revolution. thus it's highly unlikely that any dbris went anywhere as there would have been no oil flow.
Only reason I can thing of for this to happen is a manufacturing defect that eventually caused fatigue and the tip of the slipper plate cracked off.
jon928se is offline
Old 05-19-2010, 01:45 AM
  #42
hacker-pschorr
Let's just say a misplaced foreign object was the culprit and the fact that 16V cars do not have a screen on the pick-up (mine does now). Sublimate nailed it in post #2.
Not my best moment playing auto mechanic. Good news is the same motor is still in the car.
Even if it were a valve bender, it never went out of cam timing. There were enough teeth on the belt to keep the cams spinning.
Quick Reply: Has anyone seen an oil pump do this? Seized pump - internally broke apart.
