Cost of LSD?
Under the Lift
Although I avoided it entirely somehow, we used to have pharmceutical grade tablets in Berkeley in the late 60's manufactured by Stanley Owsley. The tablets had his initial embossed into the surface. He had a professional-grade manufacturing operation in the nearby suburb, Orinda. I remember watching a guy buy 2 MacIntosch amps at a stereo shop in Berekely around that time. These amps were about $2k each - very serious money then. He signed the receipt - Stanley Owsley. That's the closest I came to LSD, although I should acknowledge that I attended the Trips Festival in SF in 66.
But, back to the present and your question...
I bought an used LSD unit for $950 recently from 928 Intl. When you buy a used tranny, whether it has LSD or not is usually not much of a factor in the price...maybe a few hundred if anything. The price of the tranny is also quite variable depending on miles, whether it has been rebuilt, AT or MT, early or late model. I've seen good used 4-speed AT for $500; 928 Intl sell rebuilt AT for $2K exchange, MT rebuilt for $2.5K. Not sure if that includes the diff, but it really should since the ring and pinions are factory matched pairs. They list used LSDs - early for $650, later (83+) for $950.
Administrator - "Tyson"
Thanks for the 928 International suggestion.
Knowing nothing of 928 transmissions, what is involved in installing a limit slip differential into a 5 speed (86 1/2). What other components and gaskets are needed? If a person has have decent wrench skills, is this a do-it-yourselfer?
Thanks again.
Mark
Thanks again.
Mark
Under the Lift
Thanks again.
Mark
Thanks again.
Mark
Thanks for suggestions where to find a unit.
Beyond the limited slip differential itself, what other components are needed for the swap? Gaskets and what else?
Am I accurate that any LSD unit will fit into any transmission?
Is reasonably a do-it-yourself project if a person has some wrench skills?
Mark
Mark
Road Warrior
nope. MY stuff needs to match or it's a real mess to retrofit. plan on dropping the rear end or fuel tank to get access (since I had a fresh trans, I had the tank pulled to replace all the rotted 20yr old rubber stuff under there)...
I got mine from 928 intl also.. they had recently bought out a trans shop and had a bunch of them at some pretty good prices, iirc..
just for fun, I had all the bearings replaced and a custom shim/clutch pack installed in mine to increase the lockdown a tad, but you'd need a machine shop to do all the bearing work, so it's easier to just take it to a decent trans shop and let them mess w/it, imho.
also a good time to ck the CV's and boots, axle bearings/seals, etc WYIT.
iirc, earlier units use more shims and clutch plates, but either version can be built w/different thickness shims to vary lockdown to some extent.
Under the Lift
Mark:
What year 928? There are two year ranges for the LSD: pre-83 and 83+. In 90 Porsche went to hydraulic PSD. The LSDs fit AT or MT.
Originally Posted by Hacker-Pschorr
Here I thought the early LSD units were more desierable due to the higher lock up.
Just as a data point, I paid @$300 to have an LSD (purchased from 928 Intl) installed in a transmission several years ago. The tranmission was already out of the car though.
Originally Posted by FlyingDog
IIRC, later LSDs can be fit to earlier trannies with shims, and earlier LSDs require expensive machining to fit later trannies. Later LSDs can be rebuilt to the same 80% lockup as early LSDs.
