What does a 70+4 torque spec mean?
I am checking everything while I have the clutch out, and the flywheel bolts say they are torqued to "70+4". Does that mean they should all be torqued to 70 first then to 74 after that or is there some other meaning?
TIA!
TIA!
John
I think you have it right.....after they are all at 70 then go back and set them all at 74......seems kinda pointless....but I'm sure there is a reason?
Originally Posted by IcemanG17
John
Originally Posted by Vilhuer
Either that or anything between 70 and 74 Nm and 70+4 is just different way of saying 72 +/- 2 Nm. In any case 74 is fine.
Good point John. 70 sounded so nice round number I automatically thought it was Nm. Many times ft/lbs is not rounded to 10 or 5 as original measurements are in Nm.
While at it, one more though about original question. WSM makes many assumptions about mechanics abilities and knowhow of good procedures. This meaning that many obvious things are left out. That it's good to mount flywheel straight could be one of them. Thus I think 72 +/- 2 ft/lbs is equally likely explanation as two stage torquing. Normally 1st stage would be much smaller than 2nd.
Bill Ball wrote: "If an item requires 2-stage torque, the manual says so. This is just an unfamiliar way to state a range."
Or a typo that left out the "-"
I usually do at least a two-stage torque anyway.
XX + Y Nm is used in several places in some old factory documents and WSM pages to describe range. Maybe factory typewriter didn't have easy way to make +/-.
I don't think there would be really a point of having a two stage tighteting sequence, with first stage being 70 and second 74. As Erkka said, first stage is usually closer to being half of second stage. So, they are probably stating a range there...
Klim
Klim
