G-Tech run in 928SP SuperCharger - 0-60 <4.4sec!
#31
Originally Posted by Tony
When you get some more runs, email me the FILES, and i can overlay them on mine. Virtual drag race ![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
#32
Originally Posted by Larry928GTS
Is this forum capable of having G-Tech files posted on it? It would be interesting to see some of the comparisons and virtual drag races between boosted cars, stock cars, before and after boost, etc.
#33
Might be nice to post the weights and wind resistance(drag) for different years, wing , no wing, etc. These numbers need to be entered into the g-tech, and it would be nice for comapison if everyone was working from the same numbers.
#34
Supercharged
#35
I'm looking forward to getting mine. I orderd it two days ago and then this thread came up. Must be a sign. I actually need it for a cycling coaching test, but you know it will live in the 928.
#36
That Gtech is just too cool. I just ordered one off ebay and should have it by the weekend.
I wonder how close the HP readings would be if you could enter in all the correct data. I have truck scale just down the road from me; think they will let me weigh my 928?
Is there a part in the program that you can plug in the drag coefficient of the car?
#38
Administrator - "Tyson"
My friends modified ZO6 was within 5hp on the G-Tech compared to the RWHP on a DynoJet.
#39
Originally Posted by zoltan944
sweeeeeeeet. Tim we need some runs from you too!
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
#40
I assume you would be able to as there would be no way they would be with in 5hp of another?
What year z06?
#41
Supercharged
One more note, The G-tech likes to grab 3rd gear for the HP/TQ curves. Ideally, you should short shift to 2nd and 3rd and then mash the pedal to get the best spread of RPM range for the HP/TQ curves. I'll try one tonight.
#43
Its been a while but i cant recall if you can enter the drag coefficient on the GTECH or not?
What year z06?![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
What year z06?
#44
This is a screen shot of one of my runs and Andrews. The red horizontal line is 1320ft...(the 1/4 mi line)
the other chart is "G's"...i pull harder on the launch, but he pulls harder through the gears and down the 1/4. cool tool huh!!
#3 is RPMS. you can see the effect of the short gears in the GT.(open Kiborts can of worms here
#4 is speed over time
Anyway...Pretty damn close. As usual it would be R/T, launch and driver skill in the end.
He trapps a
speed though!
You have 12.4 in that car easily.![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
I need to hack down the 2.2 60ft time. I havent ran the GTECH on the car with my 295s yet, perhaps that will help?
Dang this thread is updating quickly!!
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
He trapps a
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
#45
I bet your HP shows way higher with the 4150 lbs input.
Also, I would say that Andrew is putting out more HP than what shows. Maybe the weight number is one you could play with to get it to match a typical dyno pull.
