what other cars used the speed sending unit
well im off to the salvage yard and just whant to know what im looking for. Dose any one know what other cars the 84 speed sending unit was on??
thx
thx
Most of us will have NFC about what what you are asking...
Other cars, as in rest of world, or Porsche, or the same year as yours.. and good luck finding any in a scrap yard.
Post the year, etc, of your car, and someone might be able to help.
Doesn't an 84 have ABS? I thought ABS cars used the ABS signals. Early cars have the sending unit for speedo pulses inside the transaxle, but it's more common for the wire connector in the spare tire compartment to get corroded and interrupt the signal. I couldn't find it with a quick browse through PET.
All 928 use same transmission sender unit up to midlle of '90 model year IIRR. Having ABS or not don't make a difference. Don't know if any other cars use same unit.
Team Owner
Later model GTS uses ABS signal from one of the front wheels to monitor speed
its a mercedes transmission soldent ther be a mercedes car with the unit on it or another porsche with the same unit i was looking at parts and i think some of the 944 used the same one i tryed unpluging it and pluging it back in (10 times lol) so im thinking that its the sending unit itsself i have a 84 928 and it is the pulse sensor
Skywurz, only the 4-speed trannies are Mercs and even their differential housings are Porsche. I'd guess it's a 928 only part unless you can find it on a 944 or an Audi.
Very few Euro 84s have ABS, which I think is just a generic Bosch add-in system.
Originally Posted by Normy
PS: NO '84's left the factory with ABS. It was an option on ROW cars starting in the '85 model year.
Originally Posted by WSM Page 45-01
As of MY ‘84, the Porsche 928 S is optionally available with anti-lock system (ABS) (option M593).
As of model year 1986, the 928 S is fitted with *** as standard equipment worldwide
Originally Posted by WSM Page 45-6
ABS relay
Removing and installing
1. Flip up cover of Central Electrical System in
the passenger’s footwell.
2. With the ignition off, pull out and insert
ABS relay, respectively (electronic relay
with overvoltage protection).
Note
The relay is located in the lower row of the
Central Electrical-System.
Initial-version (up to end of MY-‘84 Relay No. Xl (arrow).
The top of the relay is fitted with a 10 amps
fuse insert (little fuse) that protects the ABS
circuit.
Modified version
(MY ‘85 to MY ‘89) Relay No. XVII
Starting with MY ‘85, the fuse is no longer
located inside the relay but rather in the
Central Electrical System. This fuse carries
the reference no. 16. It also is a 10 A fuse
insert (little fuse).
Note
circuit.
Modified version
![](https://members.rennlist.com/flyingdog/ce84euro.jpg)
Thank you for playing.
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
Thanks for the clarifications, guys. I still couldn't find the sending unit in PET, I'll look again later. Seems I did see it in there at one time or other...
Got it -- it's not listed where I expected -- it's shown with the cluster. 78-84 impulse sender is P/N 928.606.210.00 and the carrier disc that holds the magnets is 928.318.024.02 up till 85. The second part is shown where I expected, alongside the ring & pinion drawing.
The pick up is just a reed relay - ie a micros switch that is triggered by a magnet passing by. I suspected mine and tested its output with a scope, and it was fine. Strongly doubt this will fail, given its encapsulation, unless it took an inpact somehow.
jp 83 Euro S AT 50k
jp 83 Euro S AT 50k
