Fuel Pressure Damper Question
Received 1,317 Likes
-What is the difference (is there is any) between the two?
-Would the one I have in hand fit for my 1991?
My mecanic is not ready yet to do the job, but I want to make sure it fits before I bring him my car.
Thank You.
Bertrand - Cobalt Blue 1991 S4.
Thank You.
Regards,
Felix
Felix,
It's been a while but, if I remember well, I think it was not the good one and exchanged it for the right one.
...But that's a long time ago and not 100% sure.
Archive Gatekeeper
Assuming you are putting this damper in your S4 pictured in the avatar, 930 110 602 00 / 0 280 161 021 is the wrong part. It is used in '84-89 911's and '83-86 928's.
For '87-95, AFAIK the Porsche and Bosch numbers should be as follows:
Front damper (3 ports, inlet on the bottom):
928.110.202.01
0 280 161 034
Left rear damper: (2 ports)
930.110.602.01
0 280 161 035
Right rear fuel pressure regulator (3 ports, outlet on the bottom)
1987: 928.110.198.02
1988-95: 928 110 198 04
0 280 161 297
Now, whether using the 930 110 602 00 damper in an S4 has any functional effect, I dont know. But I tend to believe that if Porsche went to the trouble of spec'ing a different damper when they changed the FPR in '87, there must be some reason the 602 00 isn't ok. But perhaps Bertrand will chime in with what he ended up doing.
928.110.202.01
0 280 161 034
930.110.602.01
0 280 161 035
0 280 161 297
milrad (05-31-2020)
Basic Sponsor
Correct Bosch number is 0280 161 035 = 930 110 602 01
Currently not available under the Bosch number from my many sources.
Only available as 930 110 602 01 via Porsche and my price is $191.
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
I'd go with the guy who posted above you that sells them weekly.
Thank you so much everyone for your responses. I found the correct part for my vehicle is indeed 93011060201 or 0280161035. The other part number mentioned ending in 297 is for the FP regulator. I found that the part number was changed from 86 to 87 and later to accommodate higher bar pressure (3.8 vs. 3.5). I get the same price Roger is getting at PCNA Dealers. Roger, I will touch bases with you soon and thank you for everything you do for us on the forum.
I hope you are looking for other after market suppliers in China if that's the goong price these days!
Last time I purchased a complete set of 3 [about 9 years ago] I think I paid about $200 for the complete set!
What did we get into?
Regards
Fred
