DR screwed me... TWICE!
#92
Rennlist Sponsor
Originally Posted by Imo000
My wife's old car was a Duratec 2.5L V6 DOHC Ford Contour, at first glance the TB looked very simillar, then I noticed the littel "Ford" oval on the driver's side TB. This is great, there are tons of them (Contour or Taurus) in the junk yards, so part availability will not be an issue!
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
#96
Owns the Streets
Needs Camber
Needs Camber
So how many guys have you recruited to sit in the back hatch area when you run the
dyno, Andrew?
Not sure what's the optimum tire pressure for maximum dyno wheel adhesion.
Ernest (NYC) Stock Atmo Motor
dyno, Andrew?
#97
Dave,
Time to install a dyno in your garage. You have just about everything else (including an oscilloscope - impressive). Maybe the next run they can calibrate it using RPMs on the x-axis instead of MPH. I'd rather not do the conversion - my head hurts.
#98
Rennlist Sponsor
Originally Posted by Flott Leben
Dave,
Wouldn't want you to get a headache so here is a tuning run (obviously A/F not perfect yet) that is plotted in Engine RPMs. Run starts at approx 1500-1600rpm with over 300rwtq :-)
#102
No, the Spanner is much handier to keep in the glove compartment of the car, than a laptop based version.
The fault panel for EZK is essential because it is a waste of time remapping the igntion if there is a knock sensor or Hall problem. These faults are rather obscure....
.............and yes, I had noticed that this "car" in the screen shot is running at 3500rpm and 75% load while still in Park :-)
This is because unit is being driven by the test jig
#103
Will the LH and EZK be packaged as one SharkTuner or be sold separately? I like the fault buttons on the EZK screen. Any chance of putting a similar feature on the LH screen as well (or are they already there and I just didn't notice them at DR's place)?
By the way, there were many impressed fans of the SharkTuner at SITM.
#105
Rennlist Sponsor
Originally Posted by Andrew Olson
I was one! That's for sure!
I have found the SharkTuner to be just as valuable as a troubleshooting tool as it is a tuning tool. But, unless I missed something (or John's holding out on me:-) the ST cannot read all the error codes and certainly can't clear them. That is where the Spanner or Hammer comes to play.
