A couple engine choices - lets discuss
Originally Posted by heinrich
Adam I'm looking for options, cost saving for performance. Bill, I'm very interested in how the rods and pistons were made to fit ....
This might be why the combo fits... I know the crank still has its original journal sizes and the rods look unmodified. If Garrity finds something different with the rods, then he'll tell me.
The way I see it, my most likely option for lowest cost and performance gains, is to use the GTS crank I have with GTS rods and pistons. If I can use S4 or other 32V pistons and/or rods, that is undoubtedly the way I'll go. I know that the GTS piston has a shorter skirt and higher mountpoint for the rod. Bill this is interesting that you have GTS pistons and S4 rods. In theory the rod is shorter and mounts higher, meaning that this is a lower-compression combo than GTS or S4. However there must also be increased side loading on the piston as a result. I wonder if I can somehow have my 5-litre pistons modded to give me good compression with stock 5-litre rods and GTS crank.
It would seem that the only way to run any 5L components on a GTS crank would require either facing off the crown of the 5L piston and/or resizing the big end of the rod to decrease the beam length. I think you'd be removing a lot of metal in either case, and if it were physically possible (meaning the parts actually survived the machining) its seems that you would be left with some seriously weakened parts. If you have access to a GTS piston and rod combo, set it next to an S4 combo and you would be able to physically see how much shortening you would have to do.
the ring lands look roughly the same height/thickness and given the cast S4 pistons withstand some boost then the GTS piston should withstand it even better as it is forged. do rods mainly fail in compression or under tension? i cant remember exactly but i think its under tension ie over revving. with that in mind how much of an issue are the GTS rods being slightly 'wimpy' by comparison to others. to me the biggest advantage with more modern rods and pistons is the weight saving.
I just compared the stock S3 32v piston/deck height compared to a 951 piston in the same block on the same 928 rod (factory standard bearings, both rod & crank). 951 piston sits 1.9mm lower in the block, not 5mm as previously posted.
Using an S4 head to reduce the combustion chamber size & bring the compression ratio back up, 1mm or so needs to be removed out of the 1.9mm to get an approx. 8.4:1 compression ratio: surfacing of block/head (.9mm or so combined), or custom rods 1-1.9mm longer. I'll check tolerances & such, but 1mm of total area to be removed from the block/head is not a lot. I'm investigating surfacing the head to it's maximium, then taking the rest out of the block to get my total 1mm or so.
When building my last 928 motor, the OEM ring set said for 100mm bores: 944, 951, 928, S4, GT, GTs if memory serves.
Its funny that you posted this. I just spoke to the red car owner last night about his current projects.
We didn't discuss it, but I know his first or so engine was a regular S4 engine with the 951 pistons. Now I don't think he even surfaced anything, but he was extremely happy with that engine and the fact that he safely ran ALOT of boost up ro 20psi I think.
He siad it was a bit weak on the lower RPMS because of the lower compression, but after 4k, a screamer.
Marcus Hutchinson? I sold him his pistons & recommended that route for him, though he had custom rods made though, unsure if they were longer or not. Also, Marcus' car was an automatic.
You know it was stolen right??
bummer.
bummer.
H,
I believe, but not sure, that the S3, S4/GT and GTS rods are the same length. The longer stroke of the GTS is handled by moving the ring stack and rod pin up in the GTS piston. Not a shorter rod. The S4 rods you have may work with a custom piston and nikasil the block, or GTS pistons. The S4 rods are probably heavier than the GTS rods so depending on the weight of the pistons you might have to use heavy metal to balance the crank. That's expensive. The S4 rods held up well in Todd's highly boosted, S4 so rod strength doesn't seem to be a problem.
bummer.
bummer.
