928 Forum 1978-1995
Sponsored by: 928 Specialists
Broken Driver Door Handle...
Old 09-01-2006, 09:51 AM
blown 87
Rest in Peace
blown 87's Avatar
Yep, went there 2 weeks ago. It is really not that bad, I even put the anti theft shield back in
Old 09-01-2006, 07:32 PM
85fortheDrive
Artist Formerly Known As 84totheFloor
85fortheDrive's Avatar
If you're like me, you'll have the most fun with the security plate.
Don't forget to reattach the little white connection unit for the door lock assembly. I forgot that one and had to go back in. Upon doing so, I found the security plate waiting for me.
Whatever the metal or alloy it is that makes up the part, it seems kind of cheapo to me. Seems brittle in cold weather.
My $0.02
Good Luck
Old 09-01-2006, 08:33 PM
Shane
Sharkaholic
Shane's Avatar
Originally Posted by auzivision
The driver’s door on my car has become increasingly difficult to open. I can still get it opened, but it takes a good tug. Works perfect from the inside so my guess is I need a new door handle release mechanism.
While I’m in there, I want to look at the window tracks or whatever guides the window up and down. While it always goes up and down, it is somewhat wobbly, noisy and much slower than the passenger side.
Also, the window trim around the outer perimeter has a 15 inch split/tear and hangs down when the window is open. I’ll add that to the list.
One last thing is the little courtesy/safety light in the door jam is missing. I have one of those in stock so now will be a good time to install.
Anything else I should be looking at while I’m in there? Any tips, advice or links would be greatly appreciated.
87 S4 Auto
There is an adjustment in there that can help with the outside door handle to make it easier. I adjusted mine as it was hard to get open from the outside. Once I got in there I saw Item #41 was broken on one side. It has been like that for 3 years now. I keep waiting for it to break the rest of the way, but am in no hurry to replace it till it does.
Old 07-09-2010, 12:05 PM
mj1pate
mj1pate's Avatar
Originally Posted by IcemanG17
Its a right of passage in 928 ownership...I've done two (luckily not mine).....first time is a pain...but it gets WAY easier the next few times.....do a search and there are several links....George's site helped alot
http://sis24.berkeley.edu/928/wk-door-handle.html
Same problem here now. The link doesn't appear to be active anymore. Anyone have the guide for fixing the broken door handle linkage ? Thanks.....
Old 07-09-2010, 12:31 PM
auzivision
auzivision's Avatar
There is a whole bunch of links in here:
https://rennlist.com/forums/928-foru...-write-up.html
Quick Reply: Broken Driver Door Handle...
