Can you fit a G50 differential in our cars?
a welded full locker rear end makes a car UNDERSTEER horribly ..... on any moderate to tight corner. manuveering in the paddock the rear tires chirp and shudder as the wheels try to ALWAYS TURN the same speed ALWAYS and that means straight line straight ahead !
Former Vendor
A welded differential is illegal in many racing venues where they know how dangerous these things can be. They should be illegal everywhere.....think about what happens when one axle or C/V joint fails. The car instantly makes a severe turn in the direction of the wheel that is still driving. This is awful when launching a car and is really, really awful if it happens at speed.
Drag race cars use spools.....welded differentials are illegal almost everywhere. Please consider things carefully before you make this modification.
Jim Bailey correctly answered your original question.....a G-50 limited slip isn't even close to fitting.
The PSD units don't work very well in any application when they are not comtrolled by the computer. We tried one for years in a race car (without the computer controlled pump and servo) and finally gave up and installed a earlier limited slip into the GTS gearbox we were using.
Originally Posted by SharkSkin
Time for a Corvette tranny?
Hmm
So a G50 won't work...the corvette 6 speed won't fit either..but this company says it does
http://www.motodyne.com/frames/porsche_928_6spd.html
What about a 6 speed from a 968 turbo (euro car)....would that fit.....probably gonna be expensive?
Administrator - "Tyson"
Brian, please delete that post. Throw your wallet out the window, better investment than dealing with those guys.
I fail to understand why anyone would want to install any of the mentioned transmissions, even if they did bolt right in. The 928 transmission works well, does the job and can handle some very serious horse power (the autos even more so).
As for the 951 trans in a high hp 928 seams like a bad idea to me. I've talk to more than a few 951 owners who have broken R/P in modified 951's. I can only imagine what the extra weight and added HP of the 928 would do to that unit.
Originally Posted by Hacker-Pschorr
Brian, please delete that post. Throw your wallet out the window, better investment than dealing with those guys..
I have heard bad things about them.......if the experts here all say it won't fit...makes you wonder why they think they can make it work?
Virtually ANYTHING can be made to fit all it takes is $$$$$$$$ There is a well know custom car builder who is fitting a 928 trans tube , clutch into a old Ford roadster.....just takes $$$$$$
Ok ok no welding.
Sooooo on to Plan C.
I was looking through the PET catalog for 928's and noticed that there seemed to be some interchangeability with the parts in the differential of a 917. So can you fit a 917 limited slip diff in a 928?
If someone can make the 951 box fit, surely this will:
