Did I mess up my timing belt?
1 Post
Originally Posted by Bill Ball
So, there is NO danger of the cam coming off one of the nodes and pushing a valve into a piston at TDC hard enough to so anything? Obviously at TDC you can make contact, just maybe not noteworthy contact. Is that the assertion? I'm an adventurous sort too, but I don't have the confidence in avoiding contact damage, so I lock at 45 before I remove the belt.
Originally Posted by jeff jackson
Bill...if you think about it a minute...if a valve is off its seat, and under lobe "lift"...if the lobe were to suddenly move "in EITHER direction"...the only possible consequence could be the valve snapping shut against its seat in the head...no way could it slam "OPEN"...into the piston crown. OR, am I missing something "obvious" here ???
1 Post
Garth...if the flywheel lock is in place...and the crank is "immobilized"...how is any contact not existant prior to the movement of the cams....going to occur if the cams move, but the crank doesn't ???Or...did I misread this post, and the crank wasn't secured at TDC with the flywheel lock ??? If THAT was the case...it makes me wonder how in heavens sake did he break loose the crankshaft pulley bolt without turning the engine over ???
Jeff,
I think you've just defined an interference engine - from the reverse view: if the crank is stationary ( at TDC in this case) and one bank of cams rotate more than 'x' degrees, valve piston contact is likely to occur in one or more cylinders - if not, why would it be considered an interference design?
The rational of the TB service to be performed at 45 deg BTDC is that this is the 'sweet spot' that allows free cam rotation without piston contact.
Does this permit a full cam rotation? - I don't know - but the respective piston heights wrt the deck height @ 45 deg certainly permits more cam rotation than a slipping lobe can generate.
Maybe we're thinking of different things ....
Garth,
If the crank is at 45 degrees there's still no free lunch as far as cam rotation is concerned. I think the whole point of 45 degrees is that the cams are off all lobes, not that interference can't occur. I've been in on six or seven timing belt jobs, all of which were done at 0 degrees. The passenger side cam tends to fall off a lobe, but we're talking about half a tooth, not enough to create a problem.
1 Post
Originally Posted by Garth S
Jeff,
Woah, came back in today after doing it and found 13 new posts. Great stuff, thanks for all the input. It did work out pretty well- I sort of 'walked' the belt tooth by tooth until each cam was in the right spot (thanks to help of my mom too). I didn't have any other notches- only the TDC red and my blue sharpie mark for the 45 degrees that I put on earlier on my own. After many times turning it over (by hand) they still line up. No explosions (yet) so I'm hoping for the best!
Again, thanks a bunch!
-Simon
-Simon
Shameful Thread Killer
Good show Simon, I think you're in the clear. Don't forget to check the tension in all the excitement. Thanks to Mom too!
Doc
Doc
Let us know if you need help with the tension. I did mine when it was on the engine stand, it took a couple of tries, the 90 Deg bend thing is a very inaccurate way of doing it, with the E-Bay Click tool, good results are possible. I would recoment removing the Plugs to do it proper.
When the engine is at TDC, the only pistons at the top are #1 and #6. #7 and #4 are at bottom and the rest are at mid stroke (engine order is 1-3-7-2-6-5-4-8; 1-4 are on the passenger side, 5-6 the driver side).
The passenger side cam wants to spin back a little since the #4 exhaust valve is starting to open (low on the lob) while the #2 intake is high on the lob so it is not causing rotation. Since #1 valves are all closed since it is at the start of its power stroke, there is no impact.
The driver side cam would have to spin forward in order for the #6 intake valve to open up and strike the piston since it is starting its intake stroke. Although the #5 exhaust valve is open, it is high on the cam so this cam should not move.
You should be fine Simon.
Simon, glad to hear you got it sorted out without too much drama.
BTW, damage is done by pistons -- with their greater leverage as mentioned -- hitting immovable valves and exerting force in a direction that they are not designed for. OTOH, if a valve should move like the lobe slippage described above, it's going to be moving on it's intended axis and tend to just stop if it contacts a piston, because there are no off-axis forces to make it bend. Now, there are lots of variables and few real absolutes in what I've said above, but if it were me I would have a much smaller load to clean out of my coveralls in your situation than if the crank were run into the valves. Either way the contact is to be avoided, but usually a cam slipping like that is no big deal. Do a compression check if you're worried about it.
Originally Posted by ErnestSw
Garth,
-Simon
-Simon
jebdog, not all 16V are non-interference and not all 32V are interference. According to PET, the vibration dampers with 45* marks started in US cars in 1983 with the M28.19/20 which are non-interference.
