Good tool at Harbor Freight
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
FWIW: Check out Non contact thermometer at Harbor. Just picked one up, and seems to do a good job of reading the temp at the block, thermostat, tires, etc.
Just used it to check accuracy of temp gauge, mine sits in upper 3rd quadrant most of the time, with a new 83 thermostat. Tool says 85 deg at base of temp sender, so i'm hoping this is correct!
Neil
Neil
Neil
Neil
Pretty good price, thanks.
great for tire temps when you autocross as well.
I need to replace mine. It works great on the BBQ..pool..hottub etc...until the kids drop it in!!
Under the Lift
Dave: That should be enough. Actually, I already have one of the Raytek ones that cost about $30 more than the HF model, and wanted to see if temp range was an issue.
Ah, OK. If the temp range suits you, then the next most important spec IMHO is the D:S or Distance:Spot ratio. If measuring a 1" spot at 8" distance suits you, then this unit is a great buy!
I agree, If you want real accuracy, forget IR completely and get an industrial strength thermocouple type device, and get better than .1% accuracy ... but the price sure ain't $39.99!
Neil
Neil
Stay away from Harbor Freight and any other "mainly China" tool distributor.
I bought a tool case from them once and the one I got looked NOTHING like the picture in their catalog. FRAUDs ! They said tough **** and I never bought from them again.
Stop Supporting China Crap !
sorry for the rant....
Bruce Toski
Bruce Toski
Administrator - "Tyson"
Originally Posted by Randy V
Does it work when you point it at chicks to determine their 'hotness'? ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
