Electronics quiz
Originally Posted by 69gaugeman
The two coils are for a latching relay. Energize one momentarily and it stays latched. Energize the other and it will unlatch.
The two relays are the same current carrying wise. You could probably get the original at electrosonic. you can take that one in or look at the spec sheet posted earlier. Also I think future electronics might have it.
you can see the spec sheet for the new relay here http://www.sunhold.com/tna.html
by the way there aren't any more radio shacks in Canada any more are there?
At least not down here anyway.
Hey 69gaugeman:
Thanks for your input. I'd really like to replace it with something more beefy. The 2A was apparently underrated for the application and who needs another burned out AC compressor. Some guys are putting in 10A relay in place
You're right about Radio Shack. I picked up the part some time ago.
T
T
Tim,
Something else you might consider -- you could replace that relay with an equivalent unit, then mount a serious power relay(like your horn relay for example) elsewhere that would do the work of actuating the clutch. That way you won't have to hack up your HVAC controller, and the big relay will hold together a LOT longer than anything you can squeeze into the controller. Also, you could mount it somewhere that's more accessible, just in case.
Owns the Streets
Needs Camber
Needs Camber
I've seen 2nd higher powered external relay wired to intercept the factory relay signal
by the underhood jump point. Just pick the rating of your choice. No need to
worry about dimensional constraints of the climate control box.
Easy access to replace the external piggy-back relay instead of having the pull
the climate control head.
Ernest (NYC)
Ernest (NYC)
Shameful Thread Killer
I disagree that this is the same rating as the original relay. My clutch relay failed just as all the others failed, and I used an aftermarket relay exactly like this one as a replacement.
You will need six pigtail wires, about 8-10" long, of 20-22 Gauge. Think of it as three sets of two wires. One set for the coil, one set for the + supply sometimes called the wiper, and one set for the NO, or picked contacts. coil is pins 1 and 16 from the board. wiper set is pins 5 and 12 from the board, and picked pins are set 8 and 9 from the board.
The coil connection is obvious and goes to the wires all alone on the end of the new relay package. Polarity is not important. Connect to the AC board at locations 1 and 16.
The + supply wires go from AC board, (middle set of pin location 12 and 5 from old relay) to the middle group of pins on the new relay which have the bent arm that looks like a wiper. Pin holes for pins 9 and 8 of the old relay(location 9 and 8, far left in post #19) will connect to the Normally Open pins of the new relay which are near the edge, furthest from the coil pins. Note that in post 12, pins 8 and 9 are clearly NO, as is typical of relay logic.
If the wiper and NO set are reversed, it really won't matter in this application. Just don't use the NC contacts and you will be fine. Once the wires are in place, I just glued the relay to a metal post behind the AC control head, and pushed the AC head in normally. Tin the wires with solder, and push them into the board, then solder from the side that has a small copper ring for good connection.
The NC (normally closed) set of pins are not used. Operation is: When AC button is pushed, and temp at the sensor is higher than temp set on the slider, the coil circuit will energize, causing the relay to pull the wiper pins from their normally open position to closed, completing the + circuit to the AC clutch and pulling the clutch closed, thus turning on the AC pump. When the temp bulb in the evaporator reaches a determined temp, it will open the coil and release the clutch. This will cycle as long as the temp sensor is above the slider temp, and the AC button is in.
