Thrust Bearing Check!
Under the Lift
Jeff, the 85 and earlier cars have a different central shaft which is held in place by a shimmed retainer on the front side of the clamp. They don't suffer TBF unless somebody screws up the TT.
Yeah, Brendan. Undo the TT clamp. Pry so flyweel is pushed to the front, zero, then pry to the rear and read.
Bill,
FWIW for whatever reason.
Neither, Zack's Great White -81'-, nor, 'Pattycakes' -82'- the Wunder Weissach
have a shimmed retainer anywhere in sight (either side). And no indication by wearmarks of having ever been installed. Just 'Ye Olde Klampfh' mit der killer allen set screw smothered in Loc-Tite.
Used the same movement/travel dimension, but used a different method to measure.
I could be wrong ... but, as far as I'm concerned, all of the auto's need to be checked irregardless of model/year.
Bill can't remember if it was you or not when we were going thru the alternate two-part adhesives question for the clamp screw a few years ago but if it was the general concensus was to add 10% to the re-torque which I did with no slipage problems.
In any case this was a well hashed inspection project and I was hoping someone could wander thru the archives and link it.
If anyone is contemplating this 1 -2 hour project I would like to recommend that you eyeball the area in question before you re-install the fly-wheel cover and find a place to mark the shaft in such a way fingernail polish , etc..., so you can tell at a glance if there has been movement NEXT TIME.
ROG,
Waiting for you to do this inspection on your Weissach for confirmation or castigation on the mystery clamp/shim.
You ain't started yet????
Post Script
Brian,
Your wheels look more than fine...Classic.
Ahem...
Now to a more delicate issue.
Perhaps you should edit your Jpegs just a bit.
When first viewed the second picture appears to be a set of sunburned , strangled, bag berries.
I know as 928 owners we are all categorized as borderline S/M freaks but
that picture gave me some aches and pains...
ROG,
Post Script
Brian,
Ahem...
It moved a milimeter. So I pryed it back and reclamped at the lower number.
Under the Lift
I believe the provision for shim adjustment did not start until the 4-speed auto gearbox. So, 83-84US automatics have a TT with the shims. 85-88 auto used the same shaft with the groove for the shim retainer, but the shim parts were left off.
The WSM shows measuring at the front with all accessories removed. I think what we did would give the same result. We could have removed the flexplate to get right on the crank end, but the clamp was very loose and the flexplate is rigid enough that the tiny dial gauge spring would not deflect it. I think it was accurate and reliable.
I haven't done any adhesive stuff. I just release the flexplate every few months. It has moved about 3mm every time. Never more. This was Brian's car we were doing this time. It moved less. I don't know if we marked it or not.
Those fingers are dirty but you have a dirtier mind.
After all the recent posts about thrust bearing failure (TBF) I decided it was a good time to check mine. After a quick brake fluid flush to ATE Super Blue Bill B & I got to work (lifts really help)....everything check out fine.....the clamp moved 1.73mm, but it looked like more? Since everything was open we checked the crank end play...it had a slight movement, but not much...using Bill's dial micrometer it came up with a repeatable .0008" or .2032mm...right where it should be! Thats a relief!! One less thing for me to worry about! The last pic is Bill's new wheels.....very sharp....I really need some new wheels!
SecaBlue (11-18-2022)
Cool... thanks!
