Need tb/wp help
It's OK, it's not rocket science. But the timing belt system on a shark is not at all forgiving of mistakes. There is little margin for doing things half-assed, if you want to be able to re-tension after 1500 or so miles then forget about it for 50K.
Under the Lift
OK, here are few things for you to print out in addition to the two guides I link inside the timing belt.doc. These notes are not comprehensive but just things I assembled tonight from my experience using John Pirtle's & Wally Plumley's excellent guides. I also grabbed the relevant pages from the WSM and put them in a doc file.
http://billsworkshop.com/P928S4/tb/
