Lightened crank
Just received the rotating assembly back from the machinest.
Due to the lighter weight piston/pin/rod combo, over 400 grams of weight was removed.
Should rev a little quicker......
![](http://forums.rennlist.com/upload/front_main.jpg)
![](http://forums.rennlist.com/upload/rearmain.jpg)
400grams? thats less than 2lbs, on a narrow diameter. 2lbs out of 50, wont be noticable, but im sure its balanced better so that may make it even smoother!
looks nice!
MK
looks nice!
MK
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Hi Adam, I wish I had one of those in my garage! Can you tell me how they removed the weight? The reason I ask is that when I get my crank done I will be using very light pistons and rods, my concern is that if my rotating assembly is too lite it may lead to a very expensive balance. My pistons complete weigh 500 grams and the rods 580 grams. As you know the standard S4 weigh is half kilo heavier per rod and piston.
Also do you mind weighing that crank for me?
Thanks and good luck
Greg
Greg
Greg, If I get a chance I can weigh the crank, but it would be on a scale only accurate to a tenth of a pound. I don't know if that would be be accurate enough for you.
I was hoping to see the crank on the balancing jig, but didn't get a chance. I don't know what they use to drill the counterweights. This is the same shop that did the bore/hone on my stroker block, so they have a Sunnen machine there, but I doubt they would need that kind of precision for balancing. When the stroker crank goes in, I'll definitely take some pics of it on the jig.
Captain Obvious
Super User
Super User
imo wrote:
Doctor, I don't what's wrong with my baby, he's been a little "cranky", (nyuk, nyuk, nyuk,
Sterling, your reciprocating components are so light its criminal dude, do you know how much weight they took off your crank? Maybe there's an uninstalled DEVEK stroker crank floating out there that we could weigh for comparison.
I'll take my stock S4 crank, the lightened RearTurbo S4 Crank, and my 928 Intl Stroker crank and get them all weighed. It will be interesting to see how much weight they add to the stroker to balance when the time comes.
you could ask your local paediatrician to put the crank of the baby scale
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
I wish I had weighed my crank.....
Developer
I like it.
BUT - and not to make you worry - but you have moved the nodal point of the crankshaft slightly as a result, and I wonder what effect that might have.
What is a nodal point? Machinery and rotating parts set up a certain harmonic resonance at certain rotating velocities. They hum, in a sort of a microscopic, not-always-audible sort of way. But - along the rotating assembly, there will be certain nodal points where there is no vibration or hum at all. Basically, this is where the sine-wave of the resonance crosses the shaft to the other side.
ANYWAY - they like to (engineers) locate the mounts of things at nodal points to be most effective. Nice write-up in EXCELLENCE magazine today of how the tranny mounts for our 928's were moved to nodal points behind the transaxle because of the cantilevered battery box hanging off the back.
On your crank - this MAY have the effect of changing the resonance, which MAY mean that the harmonic balancer is now wrong, or that the crank bearings are now in the wrong place. They were at nodal points before, and now they are not.
I don't think that you will have any trouble, 400 grams is not all that much. But if the crank does fail, it will snap in half, and this will be the reason why.
Now your talkin'!
Your explanation of nodal points on a crankshaft I think is similar to the phenomena of harmonics on a guitar string. Can I get an "amen brother" from Widom on that, or am I in left field on this one?
Developer
Anyway, I'm sure you are going to be fine - especiually because this was done in response to matching, lighter rods and pistons.
When I balanced my engine, I found most things within 2 grams - which is about twice as accurate as your factory Ford or Chevy motor. We took them down to 1/10th of a gram anyway. Here are some fo the pictures:
https://rennlist.com/forums/928-forum/198474-balancing-the-928-engine-some-surprises.html
