Check your most recent work over and items in the vicinity. Check the vacuum lines to the flappy, regulator, and dampeners. Make sure that the flappy line is connected to the 4-way from the check valve, and that the rest are connecter to the splitter next to the MAS. Then make sure that splitter is still connected to a single line running to the top of the throttle body. Make sure that connection is in place.
If you have a vacuum gauge you can check the lines at each of the items.
With an unlit propane torch in one hand and a halon extinguisher in the other, spray propane gas over all seams in the intake tract and all vac lines while the car is idling. Investigate any area where the presence of propane causes the idle speed to change. The best torch for the job is the type with the separate hose & handle that lets you keep the cylinder upright.
A vacuum leak would cause high HC and low CO, so I do not believe this to be your problem. You are failing on ALL pertinent gasses... I would give serious thought to replacing the cats. If your car still has the CO adjustment tubes, I would have the test station stick a probe into one of the tubes and then probe the tailpipe at the same time. I'm betting the readings will be about the same.
Would have been nice to have known this little detail before... sure that will cause the kind of failure you are having. Does the line at the regulator actually have vacuum? It is not unusual for these to fail and allow fuel to be sucked into the vacuum line. This condition if left this way long enough can kill the cats, so that is still a remote possibility. Sounds like the regulator is your problem though.
I agree with Bill Swift. You should be seeing ~44 PSI at idle (IIRC) with ~55 PSI when you goose the throttle linkage and the dampeners and regulator lose vacuum. As Bill says, check vacuum on those lines at the regulator/dampener end and see if they have vacuum at idle and lose vacuum when the throttle plate opens. My bet is that you pulled off the vacuum line from the throttle body to the 5-way splitter when you were R&R-ing the balanced injectors. It is also possible that one or more of the vacuum lines has collapsed. Test those lines with the hand pump - they should not be able to hold a vacuum (when the motor is off.)
I'm getting 40 cm Hg of vacuum at the fuel pressure regulator. Fuel pressure is about 55 at idle, dropping to about 50 when revved, and about 60 with the vacuum hose disconnected from the regulator.
No gas smell in the vacuum lines or from the vacuum port on the regulator.
Failed FPR???
That doesn't sound right. It should be 55 with no vacuum (reving or disconnected vac line) and around 47 at idle.
