928 Forum 1978-1995
Sponsored by: 928 Specialists
Pictures of my lunar Lander
Old 02-19-2006, 07:18 AM
Fogey1
Fogey1's Avatar
Lots of work. A new intimacy with your car is born, eh?
Is that stuff self-adhesive?
Did it come rolled on the cardboard tube in one of the pix?
Source? Googling Raamat got nothing useful.
Old 02-19-2006, 07:52 AM
unclenick
unclenick's Avatar
Originally Posted by 928andRC51
Get that cat outta there!!...
Funny, that is the first thing I thought of too on the new paint!!!!!!!!
Looks good, lots of hard work there laying that stuff. Good job
Old 02-19-2006, 01:08 PM
BC
BC's Avatar
Yeah, in the cardboard tube. Maybe I should have cleaned up... Its is a peal off back, but the surface has to be TOTALLY clean. This will be easier in the 89, and many other cars with some simple spririts cleaning, but this car was dirty like you wouldn't believe. There was a pound of dirt and twigs INSIDE the Heater/AC core box.
Ah, I found it: http://www.raamaudio.com/
Old 02-19-2006, 01:09 PM
BC
BC's Avatar
The cat tracks you see are inevitable... They just use thier claws more whith a car cover. They are filled down all the time. I can't wash the car without the windows in.
Old 02-19-2006, 01:47 PM
EB338
EB338's Avatar
How does this Raamat material copare to Dynomat?
Old 02-19-2006, 01:50 PM
BC
BC's Avatar
I read in my research that Dynamat extreme is the only stuff that can compare. And that stuff is about as expensive as gold. The amounts you get for the prices people pay, you may as well buy stuff with Porsche stamped on it.
I will have to do my doors, so I will see what is out there or as I mentioned if Rick can send a smaller amount to me.
Old 02-19-2006, 02:24 PM
Tony
Tony's Avatar
Catch one hullova tan driving around SOCAL in that thing!
I need to to the inside of my wheel wells also..very noisy on the conrete roads out here.
Old 02-19-2006, 03:10 PM
SharkSkin
SharkSkin's Avatar
Damn cats -- I finally put some strong spring hinges on the door from the garage to the house, because the cats love to follow the other half out into the garage, then get trapped out there with nothing better to do than scratch up my car... Now, the garage door slams shut as soon as you let go of it. Problem solved!
Old 02-19-2006, 03:46 PM
BC
BC's Avatar
Well, the cat's food and ****ter is out here in the garage, so...
Does anyone have a pic of where this external dampening stuff goes in the wheel well?
Side note - today was the day to remove the windscreen from the 89S4 sitting next to the 78 - you know, save money now, and spend more later to get a new one for the 89.
Sawing with the piano wire, getting it all ready to remove, allmost out, pulling at the bottom......
CCCRRRAAAACCCKKKK.
Nice.
Windshield info? I have seen a few threads, I'll do a search.
Old 02-19-2006, 04:24 PM
ew928
Owns the Streets
Needs Camber
ew928's Avatar
Thought the wheel well foam filling went in at the B-pillar (6.5" speaker) speaker
opening.
Tempted but haven't foamed my rear wheel well yet.
Ernest (NYC) PO had only squares of Dynamat installed in the rear hatch.
Old 02-19-2006, 04:29 PM
EB338
EB338's Avatar
Brendan, You have a link to the manufacturer of this stuff? Did you just stick it on? Roll it down? Did you apply heat to get it to conform to contours?
Old 02-20-2006, 01:37 AM
bd0nalds0n
bd0nalds0n's Avatar
I used brown bread to do some sound insulating, it looks a lot like what Brendan used. It was quite a bit cheaper than Dynamat. You peel off the backing and it reveals the insulating material, which looks a lot like a cross between asphalt and black Permatex. It's pretty gummy. It comes in rolls.
http://www.hometheaterhifi.com/volum...ng-6-2003.html
Old 02-20-2006, 03:21 AM
m21sniper
m21sniper's Avatar
Originally Posted by sweanders
How much does that stuff weigh?
That's the first thing that popped into my head when i saw the pix too.
Old 02-20-2006, 09:46 AM
Evil Patrick
Evil Patrick's Avatar
Foam earplugs are lighter and cheaper and install in less time.
Old 02-20-2006, 01:36 PM
BC
BC's Avatar
www.raamaudio.com
Quick Reply: Pictures of my lunar Lander
