Supermodel uninstallation HELP needed
He shouldn't need a new cable as Andy's setup involved using a custom cable in place of the stock cable to the throttle body. So, Derek should have the original cable in his spare parts.
I would love to do this closer to home if I knew we would have access to parts. I would hate to have my car stuck in someone's garage due to lack of parts.
Derek...Is the plan to keep it stock for the forseeable future or go back to SC... If you are going to keep it stock I would suggest replacing all rubber that has not been done recently... good thing you have the PET.
If I recall this is your everyday driver.
Here we go... this is from memory so I am sure that I will forget some detail.
These are needed ...depending on how good or bad your stuff was you may have to reaplace....
Passenger side crank breather hoses...
A few hoses around the throttle body...
2 hoses for the idle stabilizer...
New intake gaskets... Metal if possible but paper ones are way cheaper...
vacuum lines and connectors....
You may want to change this stuff especially if you want to keep her stock for a while.
Rubber sleeves on intakes.
Rubber sleeve to throttle body
Rubber sleeve to MAF
Baffled gasket to oil filler neck... (buy a devek one.)
MAF o-ring (big)
Throttle body o ring
idle stabilizer valve. (hard to get at later)
Hoses from drivers side plenum (vacuum to brake booster)
Fuel lines...
sounds like you still have your....
air tubes..
airbox and filter
The big macaroni shaped air tube that connects the MAF to the Throttle body.
four intake runners (two tube each)
oil filler neck
Tee shaped intake and two plenums
clamps for all the hoses and sleeves... and any nuts and bolts that were left over.
Crank pulley.
pullies on PS air pump...
fan
shroud,
I remember that the wiring to the throttle switch was lengthened during the install. Bill remembers that a fuel line was modified so you will need that.
hmm...
I am sure that I am forgetting some stuff...
LO
Thank you for offering to join in on the surgery, Brian.
I seem to have most, if not all, of what is needed including my old injectors. I plan to clean the injectors with carb cleaner, they look a bit grimy.
I plan to order:
a new set of vacuum lines and connectors
fuel line # 928 110 269 01
MAF o-ring
Throttle body o-ring
Two large intake runner sleeves
One small intake runner sleeve (the rest look good)
A new set of wr7dc spark plugs (wr6dc installed now)
My intake gaskets are the metal ones and I have them all. Do I need to order a new set or will these work?
All of my hoses appear to be in excellent shape.
Sounds good....
You can use the gaskets over... is there a little hard ridge around the edge... Even if it is a bit flattened out if it looks good you can reuse it...
I remember you said that you had some intake work done before the SC install... that may be why a lot of your stuff is in good shape... are the little vacuum lines any good?
LO
The vacuum lines are made of a hard plastic and appear intact. I may be missing a few connectors.
I had my cam cover gaskets, coils, rotors, distributors, t belt, w/p, air filter and fan motor replaced prior to the s/c install. I've since replaced my spark plug wires, o2 sensor, two fuel hoses and maf.
I did not find a throttle cable. Do our cars have one in stock form? I did find a rod with a ball connector at either end.
MAF o-ring (big)
Fuel lines...
air tubes..
airbox and filter
oil filler neck
Crank pulley.
fan
shroud,
hmm...
LO
It's going to cost more to take the thing off than to keep it on!
It's going to cost more to take the thing off than to keep it on!I placed my order for the remaining items yesterday, it totalled $175.
I wish I could afford to keep it on...I will miss the power tremendously. I'm trying to barter for some AA chips from another Rennlister. I sold my AA chips after I installed the s/c.
So, the metal intake gaskets are reusable right?
