I beat the odds again. (fuel pump)
Under the Lift
155K miles. In-tank pump is perfectly intact and with only a slightly dirty screen. The short hose that joins the pump to the outlet usually breaks before now. It is still pliable.
Under the Lift
Originally Posted by the flyin' scotsman
Bill..........now that its out will you replace it?
Why did you remove it anyway? PM.
https://rennlist.com/forums/928-forum/249567-devek-x-over-results-in-my-89-a.html
I don't know what to think. The A/F was all over the map, but fuel pressure was good, so maybe it was wrong to suspect the pump in the first place.
Under the Lift
Jim:
That's what I was expecting to see. I'm on the original steering rack too. How weird is that?
I've run the tank down to fumes a few times and I never refuel until I'm down to the last couple of gallons.
Bill it's all about care. If a car sits long, the fuel tank gets crystallised or sediment, and cheap gas wil do it too. Steering rack, if you keep it running I believe it will be fine.
