928 Forum 1978-1995
Sponsored by: 928 Specialists
H4 Headlights
Old Jan 19, 2006 | 02:04 PM
DR's Avatar
DR
Rennlist Sponsor
David,
>Thanks DR. I'm definitely interested in the 8" H4's, so if you can somehow put me on a "notify" list if >some become available, I'll hopefully be ready to spring into action.
Take this as your offical notification! We currently have 3 pairs in stock and Jeannie just told me the cost has gone up on the next shipment that is in route to us. After the 3 pairs in stock are gone the new price will be $269 each, sorry. :-(
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
Old Jan 19, 2006 | 02:34 PM
Alan's Avatar
Alan
Electron Wrangler
Dave A,
Yes you are right the H4's do come with the bulbs but not the required mounting HW.
The H4 hinge mechanism has an integrated threaded stud each side that bolts to the alloy yokes - so you the need nuts/washers for it.
(however on my H4's it was only 1/side (plus dummy locator stud) vs 2 bolts for the H5's).
I agree 2 x metric Nylock M6's in stainless is the way to go. I used 2 x stainless wave washers - but not critical. Since there is only 1/ side you want it to be a very solid connection...
Alan
Old Jan 19, 2006 | 02:59 PM
SharkSkin's Avatar
SharkSkin
Alan, you only have one nut per side? Odd... Do you mean one per side of the yoke, or one per side of the car? I needed 2 per light, 4 total.
Old Jan 19, 2006 | 03:11 PM
DR's Avatar
DR
Rennlist Sponsor
Correction, we just recieved our new shipment and the invoice showed a lower price increase than we were told, the new price is $269.
Old Jan 19, 2006 | 03:19 PM
Alan's Avatar
Alan
Electron Wrangler
Dave,
Yes - agree - 4 total - 2 per light
Vs 8 bolts total - 4 per light for the H5's
Alan
Old Jan 19, 2006 | 03:47 PM
1981 Shark's Avatar
1981 Shark
Originally Posted by Bill Ball
Here is the procedure for US S4 and later 928s.
http://www.billsworkshop.com/P928S4/h5toh4/h5toh4.htm
I did it using a Euro donor car for the 8" H4 parts, but 928 Intl and 928 Specialists sell the new 8" H4 lamp assemblies as well.
One small issue is that the bottom post that holds the headlamp assembly, which is part of the headlamp adjustment system in Euro H4 cars, is shorter than the fixed US H5 post, and the 8" H4 headlamp assembly is dimensioned for the Euro post. So, with the longer US post, the headlamp position ends up being further forward relative to the bucket. A slot in the front edge of the bucket will fail to engage a tiny tab on the headlamp assembly that prevents the bucket from flapping in the wind, unless you swap the post assembly (good luck getting one) or do something to lengthen the tab (easy).
Other than that and the H4 electrical plug, it was plug-and-play. My compulsive description of the swap procedure makes it look harder than it is.
The H4 light pattern throws a lot more light on the road than the diffuse H5 and is a great improvement, surpassed only by the HID kits that 928 Specialists and 928 Intl also sell.
Hi Bill,
And thanks for the information; sorry I submitted my response before I saw yours and missed the "thanks" to you, as well. However, I have a couple of questions. Are you saying that I will (most likely) have to modify/splice my stock plug to plug into the H4's (or did I read this incorrectly)? Also, I read over your procedure, but am still "fuzzy" regarding the lengthening of the tab; can you elaborate a little? Thanks.
David
P.S. Sorry to hi-jack Darien.
P.P.S. Love the burnout, Bill!
Old Jan 20, 2006 | 06:27 AM
Darien's Avatar
Darien
7"
Originally Posted by hlj821
Darien, are you looking at 7" or 8"?
Old Jan 20, 2006 | 06:28 AM
Darien's Avatar
Darien
Well, which bulbs??
Originally Posted by Darien Nunn
Great which wattage??
Old Jan 20, 2006 | 10:36 AM
BrianG's Avatar
BrianG
Standard 55/55W will work with the stock wiring. If you go higher, you should increase the wire size for the extra current by running a separate, fused circuit off of the main power terminal (jump-start terminal block), and use a relay activated by the stock connector(s).
I'm running 100/85W in my H4's, and I can actually see at night, on the hiway. I wish there was a place to mount Q4509's, like I have on the truck, but "Oh well"!
Old Jan 20, 2006 | 12:49 PM
Bill Ball's Avatar
Bill Ball
Under the Lift
Originally Posted by 1981 Shark
Hi Bill,
David
The plug that is on early cars that have sealed beam headlights, like yours, is the same as the H4 plug - so, no splice needed.
I am not sure if the buckets on sealed beam headlights units with the chrome trim ring even have the tab. On the later car the headlight assembly has a little tab or prong-like protrusion on the lower part of the lamp, at the 5 and 7 o'clock positions. On the bucket's leading edge there is a hole that mates to the prong. This keeps the lower edge of the bucket from flapping in the wind and rubbing the fender. If you go with 7" H4's then this is not an issue. If you go with 8" and remove the chrome trim ring, I'm not sure if you need to do anything to prevent the bucket edge from flapping. I had to extend the tab/prong due to the change in headlamp assembly position. When the tab and bucket did not engage, the paint wore off the lower edge of the bucket. Others have done this on early cars. Maybe they can comment.
Old Jan 20, 2006 | 12:51 PM
Bill Ball's Avatar
Bill Ball
Under the Lift
Isn't stock 80/55? Anyway, I've been running 100/85 H4s for 4 years on stock wiring. No issues at all.
Old Jan 20, 2006 | 01:27 PM
Shane's Avatar
Shane
Sharkaholic
I am not sure if the buckets on sealed beam headlights untis with teh chrome trim ring even have the tab. On the later car the headlight assembly has a little tab or prong-like protrusion on the lower part of the steel ring that hold the lamp, at the 5 and 7 o'clock positions. On the bucket's leading edge there is a hole that mates to the prong. This keeps the lower edge of the busket from flapping in the wind and rubbing the fender. If you go with 7" H4's then this is not an issue. If you go with 8" and remove the chrome trim ring, I'm not sure if you need to do anything to prevent the bucket edge from flapping. I had to extend the tab/prong due to the change in headlamp assembly position. When the tab and bucket did not engage, the paint wore off the lower edge of the bucket. Others have done this on early cars. Maybe they can comment.
Yes the prong is there on the early cars as well. Straight plug and play on that as with the plug.
Old Jan 20, 2006 | 01:35 PM
SharkSkin's Avatar
SharkSkin
On the '78 there is a spring that runs between the two forward, lower corners of the bucket to hold it tight against the ring or the outer lens in the case of 8". It's kind of a PITA but with long forceps(hemostat/roach clip ) it's easy enough to get to.
Old Jan 20, 2006 | 02:02 PM
Alan's Avatar
Alan
Electron Wrangler
Bill,
Stock H5's are 45W/65W while Stock H4's are 55W/60W (L/H)
I recommend that for anything over 80W you should upgrade those
fuses (1 per side for L & H) to 10A vs 7.5A. (@ >110W= 15A, >150W:20A)
Anything >>100W you should consider a local relay and beefier wiring. This is both to
protect the stock wiring and to get full value from the upgrade.
A 130W headlamp will drop voltage across the headlamp to relay
wiring. It will lose about 10W in stock wiring configuration. It will also be
significantly less bright than intended, and your wiring will get hot.
All in all a bad deal...
Alan
Old Jan 20, 2006 | 02:45 PM
Bill Ball's Avatar
Bill Ball
Under the Lift
Hmmm...I left the stock fuses alone. Wouldn't rasing the fuse level without changing the wiring be overfusing the circuit? I figured the stock fuse should be insurance againt my bulbs drawing too much. 100/85 seems fine. Anything higher, I would upgrade the wiring, relay and fuse.
