Would Forced Induction Increase The Risk Of Thrust Bearing Failure?
I line up on the other side of the belt issue. The timing belt has been designed to withstand an engine that is revved out of gear which is certainly revving much faster than any engine in gear.
Under the Lift
Originally Posted by bigs
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
928 Collector
Bill, I'd compare it to another car and draw conclusions, but more importantly go as far as opening the damn box up and finding the exact point of forward motion.
Under the Lift
Originally Posted by Jim bailey - 928 International
Bill somehow I just have to laugh when I see your burnout video...... especially when You comment on driveline issues ! I think you need to drop that trans install a slip and figure out what is moving.
I bought a used limited slip from you guys a few years ago, then decided I really didn't have a great need for it, so I sold it to Dennis Kao who puts it to very good use on the track. That was before the SC. Have any more LSDs for an 89?
Under the Lift
Bill we have one which is not in a gear box but if you install it you will have to learn how to drive while fishtailing
! and the true meaning of throttle induced oversteer !
Dean of Rennlist, "I'm Listening"
Nuther thought -
Are there enough stroker motors in use to know if there's any increased risk with them?
Under the Lift
Marton: The AT is fine for supercharging and turboing. Maybe even better since you don't let the revs spin down by taking your foot off the gas when shifting. I see no evidence the SC does anything to accelerate the thrust bearing failure issue. In a few hours I'm going to go out and lay down a huge burnout in the parking lot here at work just for you.
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Under the Lift
Bill that has got to be one of the best real-world time tests so far. Very troubling.
If you are not familiar with Thrust Bearing Failure (TBF), my site has a lot of info and history of the "Loctite Fix" as a method of reducing thrust bearing failure. I make the claim that I have never heard of TBF on a car that has applied the "Loctite Fix". I don't know if this claim applies to boosted cars.
http://members.rennlist.com/captearlg/
Bill
I still need to check my flexplate?......its probably fine, but its piece of mind to check it & remove those stupid bolts to make it easier next time too!
