Making Rotor Hats for 993TT rotors on 928
#76
I don't know if any of this info helps or not but a great compilation of stats on brakes.
http://www.pelicanparts.com/MotorCity/wmv/brakes.htm
Also try this for custom hats.
http://www.zeckhausen.com/StopTech/consumables.htm#Hats
#78
Originally Posted by heinrich
Any real reason a spacer under the hat with longer bolts would not work?
I have never heard of this done before. If you place a spacer under the hat it will change the offset where the wheel mounts to the car.
#79
Captain Obvious
Super User
Super User
#80
Originally Posted by Imo000
yes, it will but so does if you put the spacer between the wheel and the rotor. The only reason you can't put the sacer under the rotos is that it will move the rotor away from the caliper and the breaks worn't work.
I think Heinrich is trying to figure a way to adjust the offset of the 993TT rotors he has to work with the Calipers he has. The GTS uses the big blacks with the 94 turbo 3.6 rotor and the 993TT rotors are similar but have a different offset. So I am assuming he is looking to adjust for the offset by using the spacer.
#81
Captain Obvious
Super User
Super User
#82
Originally Posted by Andre Hedrick
I have 993 cross drills on my '81 w/ S4 BB'
#83
928 Collector
I'm sort of inclined to go see if i can have a 1/4-in spacer made for the inside of the hat, so it bolts on with the weel studs as always, and leave the hat screws alone.
