928 Forum 1978-1995
Sponsored by: 928 Specialists
Drilled Crank Thoughts...
Old 10-03-2007, 12:34 PM
  #106
Vilhuer
Vilhuer's Avatar
Originally Posted by SwayBar
Erkka, how do you measure to check the opening pressure?
Exact same way as 5bar measurement is taken in WSM except that cambelt is off and just oil pump is rotated. Even cranking by hand is enough to raise the pressure but he used electric drill. He tried if it makes any difference when rotation speed is increasing or decreasing etc. End result was always same much below spec value for stock setup. Oil pump should be easily able to create enough pressure for measuring. Thats not a problem unless pump or engine needs to be changed anyway.
How many washers were required? What was the resultant oil pressure? Do you have any pics?
He ended up changing new spring to another one which was sourced from somewhere else. With it it was possible to adjust desired pressure from 5bar to above 10bar just by adding different thickness washer. He set pressure to little above 8 with about 1mm thick washer. He didn't want to use stock spring as it would have required much thicker setup.
Other problem he noted with old stock spring is that it hadn't been positioned straight. This was visible from uneven wear it had in coils. So into new setup he added small rod which purpose is to keep spring straight.
Very interesting hypothesis!
I'll be doing exact same measurement when GTS engine is installed. It can't hurt to do it and adjust spring to open little above stock value. If new stock spring can't do it its easy to fit something else. Total cost will be nothing compared to possible benefits.
Old 10-03-2007, 01:05 PM
  #107
SwayBar
SwayBar's Avatar
Thanks for the info Erkka.
Old 10-03-2007, 01:09 PM
  #108
Mike Simard
Mike Simard's Avatar
Erkka, what do you think about the idea of having oil pressure that increased proportionally to rpms? I've always heard of terms like "10psi per 1000rpms" and yes it would be desirable to have higher pressure at only higher rpms but how do you make that happen? What if the releif valve's return orifice were sized such that it acts as a restriction at high rpms thereby increasing available pressure? Any thoughts?
Old 10-03-2007, 01:31 PM
  #109
Vilhuer
Vilhuer's Avatar
Oil pump has probably some rpm related asjustment build into it just by its size and general design. If this is not enough I think easiest way would be to build variable relief valve and some electronics to run it. System would need inputs for pressure and rpm. Simple result would be desired valve adjustment. It shouldn't be too difficult to build such system with asjustable resistors etc and not even need to use programmable circuits, processor or other complex parts. Not sure if I would trust something like this to do so critical job though.
Making similar setup with just mechanical parts must also be possible. Setup would probably consist several differerent size valves where very small one would take care of low rpms and much larger one 6k and above. In between there would be several intermediate valves very carefully sized so that they would correspond oil pump production at each rpm range. Sizing all valves correctly would result very similar result as having same number of steps in electronic system.
Question is would such system really be needed as stock pump acts like limiter anyway. Idle oil pressure is not same as 6k rpm. Or at least is shouldn't be if all is ok in engine.
Old 10-03-2007, 01:38 PM
  #110
Jim bailey - 928 International
Jim bailey - 928 International's Avatar
The stock pump moves 65 liters per minute at 5250 RPM according to the book , Porsche Excellence Was Expected. Or over a liter per second ! No mention of presure however. I do show the presure relief as opening at 8 Bar per the 928 service manual # 4582.21 .
Old 10-03-2007, 01:43 PM
  #111
123quattro
123quattro's Avatar
The oil pump is a positive displacement type. Flow rate goes up linearly as speed increases. As the rate tries to go up, it becomes restricted more and more by the oiling system. This in turn causes to pressure to rise. So really pressure does raise with speed. That is why there is a bypass valve built into the pump. Otherwise at high speed oil pressure would go through the roof and start blowing out seals.
Old 10-03-2007, 01:46 PM
  #112
Mike Simard
The oil pressure gage in a 928 seems to shoot up the the 5 bar maximum on the gage somewhat above idle. With the gage staying steady it looks like that's relief valve limited. Could that 8 bar reference be a mistake? If it were true, how does the gage and sending unit handle it, does it only report the maximum 5 bar?
Old 10-03-2007, 01:53 PM
  #113
Vilhuer
Vilhuer's Avatar
As factory says 4k rpm should produce at least 5bar I think 8bar limit is real. 5bar is probably enough and factory didn't see any need to display actual pressure in dash. If they had included gage that goes up to 10 or at least 8 they might have created problems for themselves as owners would notice engine isn't making as much pressure as 10k miles ago for example. By showing just 5bars max value they made sure owner is warned if something is wrong but not told what is actually going on inside engine.
Old 10-03-2007, 02:00 PM
  #114
The sending unit has a moving variable resistance unit inside which when maxed out sends a signal which pegs the gauge at 5 Bar ... much like a fuel tank sender, full is full also inside the sending unit an open closed switch signals for low oil pressure.
Old 10-03-2007, 02:07 PM
  #115
BC
BC's Avatar
Sounds like Honda!
Old 10-04-2007, 01:36 AM
  #116
GregBBRD
Former Sponsor
GregBBRD's Avatar
Received 2,474 Likes on 1,468 Posts
I
Greg I know you stated in an earlier thread that you now have your own crankcase oil control system. So instead of installing Kevin's proven unit into this new race motor:
would you be willing to install your own...
as well as...
It should be an excellent experiment at the very least. And if successful, 928 owners would then have another proven scraper/windage option to choose from.
Swaybar:
I already do this.....it's called a warranty.
Old 10-04-2007, 07:59 AM
  #117
SwayBar
SwayBar's Avatar
Originally Posted by GregBBRD
Swaybar:
I wasn't aware that you warranty your engines utilizing your new scraper/windage system; thanks for the info.
Old 10-04-2007, 09:21 AM
  #118
Mike Simard
Originally Posted by Kevin Johnson
Eight bars would be Porsche initially attempting to control air entrainment through pressure. Five bars subsequently is the refutation of a certain "centrifugal force theory" and part of the factory's tacit acknowledgement that they now (then) had a very nice GT rather than race motor.
Center feeding a crank, ala Ricardo in the 1930s (probably earlier), allows the crank to be a more efficient extension of the oil pump. Just because part of a problem treats it like a closed system doesn't mean you can or should ignore that it really is an open system.
Kevin, I'm convinced that you have no idea what you are talking about and will say anything to promote yourself and your product. You've hijacked a valid crankshaft discussion and turned it into an infomercial for yourself.
Old 10-04-2007, 09:51 AM
  #119
JET951
JET951's Avatar
Stan , just out of curiosity A) do you know the oil temp on that day on the track during that hour . B) what was the oil viscosity and or oil brand used . Regards . BB .
Old 10-04-2007, 10:19 AM
  #120
SwayBar
SwayBar's Avatar
I do not agree with your sentiment.
This whole discussion revolves around staving off a 2/6 failure. Drilling cranks, Accusumps, dry-sumping, and oil scrapers are ALL valid topics. Please tell me who is more qualified to discuss crankscrapers and windage trays?
Quick Reply: Drilled Crank Thoughts...
