928 Forum 1978-1995
Sponsored by: 928 Specialists
Drilled Crank Thoughts...
Old 01-09-2008, 02:02 PM
  #226
Stan.Shaw@Excell.Net
Stan.Shaw@Excell.Net's Avatar
Dave and I had our dry sumps built togther by a fabricator near me.
Old 01-09-2008, 02:17 PM
  #227
drnick
drnick's Avatar
stan, have you already posted pics of the sump - i cant remember? show us your and i will show you mine!
Old 01-09-2008, 05:14 PM
  #228
Circuit Motorsports
Rennlist Small
Business Sponsor
Circuit Motorsports's Avatar
Quick question about those pictures Kevin.
How are they backwards?
I was under the impression that you wanted to match the serial numbers like you see in picture 2.
Old 01-09-2008, 05:42 PM
  #229
Jim bailey - 928 International
Jim bailey - 928 International's Avatar
Actually Kevin you have no idea what you are talking about...the assembled rod /cap is machined and the surfaces you see are meaningless the numbers are matched as shown.....Try again to explain the failure...because this time you are SOOOO WRONG !
Old 01-09-2008, 05:43 PM
  #230
Circuit Motorsports
Rennlist Small
Business Sponsor
Why would the misalignment of the cap trump the serial numbers. Don't the serial number signify the orientation of the caps when the bearing surfaces were machined. I'm not saying you are wrong I just find it odd that the rod people would have screwed up the marking of the rod caps.
Dangit: those 928 Intl people are just too fast and too good.
Old 01-09-2008, 05:53 PM
  #231
It is pretty easy when you can walk 50 feet into the warehouse and look at 5 or 6 rods and see that the " misalignment " has NOTHING to do with how the big end hole is machined....
Old 01-09-2008, 06:33 PM
  #232
drnick
drnick's Avatar
bloody turks eh? seems ahmed was stationed to install all the 2/6 bearing caps for porsche 928 engines, silly fool, he was on the wrong side of the engine so he wouldnt use his left hand...
Old 01-09-2008, 06:46 PM
  #233
Nice anecdote but the point remains that the surfaces you were looking at were machined before the caps were joined to the rods and the FINAL machining of the bearing hole and shoulders was done assembled .....guess again. Also worth noting that the rods are NOT semetrical and if the cap were "reversed" would not fit the bearing journal.
Old 01-09-2008, 06:53 PM
  #234
I was thinking that as well, as I recall the rod cap being wider on one side than the other. Sure enough, it is.
Old 01-09-2008, 06:59 PM
  #235
By the way, my thinking is comparing a Chrysler operation to Porsche is unreasonable. Weren't 928s hand built as opposed to an assembly line process?
Old 01-09-2008, 07:08 PM
  #236
Vilhuer
Vilhuer's Avatar
2mm wider to be precise. Or more specifically on one side 2mm was machined away to make lower end nonsymmetric and make crank lenght 8x2mm=16mm shorter.
Old 01-09-2008, 07:33 PM
  #237
Black Sea RD
Former Vendor
Black Sea RD's Avatar
Sucks being at work and missing all this good stuff!
Dave, I read your description and did not see any mention of a drilled crank. Did your engines have a drilled crank by the favored machine shop installed in them? I believe Mark A. had installed a drysump system without drilling his crank and had 2/6 bearing failure. After crank drilling the 2/6 failure was solved for him.
Constantine
Originally Posted by mtcarrera
Two summers ago I lost a fresh 4.7 engine on the track at Portland International. That engine had a full Kevin Johnson windage tray and crank scraper and was running Mobil 1. Last September I lost another 4.7, this time with no scraper, but WITH AMSOIL and an improved breather. Neither engine was run past 6K rpm. Both happened within the first hour of tracking. On both, the 2/6 rod bearing failed.
The new engine will have a dry sump, improved breather, Accusump, and drilled crank and all the mojo I can muster.
Regarding the 300+ preceding pages of discussion, there is NO proof of anything anywhere, except that these engines regularly burn up their 2/6 rod bearings. Virtually nothing else has failed. I'm concentrating on the care and feeding of my 2/6 rod bearings because it would appear that that is the only way I'm going to get any track time.
And if this one fails, I won't need to get another Chevy drilled crank because the next engine will be a Chevy.
Dave
Old 01-09-2008, 08:42 PM
  #238
Again you do not know what you are looking at. What matters is the hole through the rod where the bearing fits not the alignment of the sides of the ends of the rod and caps which do not touch anything. And again the offset of the shoulders makes flipping the cap around IMPOSSIBLE ....try that scenerio.
Old 01-09-2008, 08:54 PM
  #239
I do not wish to waste my time debating fools...
Old 01-09-2008, 09:16 PM
  #240
Mike Simard
Mike Simard's Avatar
Jim, sorry to hear you don't conceptualize well.
Maybe this can help you conceptualize with Kevin
Quick Reply: Drilled Crank Thoughts...
