928 Forum 1978-1995
Sponsored by: 928 Specialists
S4 cooling fans on an older car
Old 01-01-2006, 09:35 PM
heinrich
928 Collector
heinrich's Avatar
Default S4 cooling fans on an older car
What is required? Where do the S4 fans get their signal? And I read the S4 fans take too much draw on current, how do they manage on an S4 then?
Old 01-01-2006, 09:58 PM
EB338
EB338's Avatar
Sarduchi?
Old 01-01-2006, 10:05 PM
bigs
Dean of Rennlist, "I'm Listening"
bigs's Avatar
...found himself lusting after the gorgeous Porsche 928 belong to the mysterious and equally gorgeous woman next door. This was a dangerous thing for an Italian member of the mob. He couldn't decide if his lust was more for the Porsche, or...
Old 01-01-2006, 10:11 PM
FlyingDog
FlyingDog's Avatar
... to avoid collateral damage to his wallet resulting from Ferrari ownership.
worf928
worf928's Avatar
Received 1,643 Likes on 1,072 Posts
... the Killer Pimp.
Old 01-01-2006, 10:12 PM
FlyingDog
FlyingDog's Avatar
How many times are you going to edit this post?
Old 01-01-2006, 10:15 PM
heinrich
928 Collector
heinrich's Avatar
Until you goofs stop responding to it
Old 01-01-2006, 10:44 PM
Louie928
Louie928's Avatar
Heinrich,
I tried to use S4 fans on Gerry's '85. There was interference between the fan housing and the A/C tube below the right radiator hose. If you were really determined, you could change out the A/C line. I think there was interference with the engine driven fan support too, but sawed that off or something. First, I used an aftermarket 16" electric fan and found that marginally effective. The final fix was to use the Devek original dual fan shroud. It takes two 11" high output Spal fans and they work well. The package is thinner overall than the S4 fans. I think with the engine off and the fans on, it will pull the car along. Sort of electric limp home mode if your LH quits. Heh, heh.
Old 01-01-2006, 11:07 PM
BC
BC's Avatar
H -
The S4 fans are driven by the standalone cooling circuit with the black box on the front area by the hood latch (finned) and the silver one that is usually under the passenger "stepover" cover next to the seat.
This system has a few parts, and runs the fans many different situations, high or low, or both (AC)
It also controls the front flap (which you removed), and IIRC, the "coolant purge" solenoid near the passenger shock tower.
It takes signals from the radiator, as well as the AC system AND it will turn the fans on at certain times when it simply feels like it. Oh, and it takes an input from the intake manifold temp sensor at the back of your S4 manifold. I saw MANIFOLD temp, as the bung does not go all the way through the magnesium as a AIT sensor would, so its basically testing how hot the manifold is, not the air.
Old 01-01-2006, 11:08 PM
SharkSkin
SharkSkin's Avatar
Regarding the current, somewhere there is a diagram of how the fan controller works -- most of the time they are running at a fraction of capacity IIRC
Old 01-01-2006, 11:16 PM
heinrich
928 Collector
heinrich's Avatar
Thanks Louie, Brendan, Dave, well I guess I should take a careful look before utting that ugly fan elbow
Old 01-01-2006, 11:29 PM
FlyingDog
FlyingDog's Avatar
Why would you have to worry about the mechanical fan support? Just take it out. I've thought about putting an electric fan in place of the engine driven fan. Some people (like Louie above) have said it doesn't work well. Why is that? I'd think one of the 3300 or 3600cfm Zircos could push/pull enough air.
Old 01-01-2006, 11:36 PM
heinrich
928 Collector
heinrich's Avatar
Man I'd love to instal the S4 fans ... Wonder if I could cut the shroud. Matt, I do't remember now ... it was all so clear before all that eggnog
Old 01-01-2006, 11:49 PM
Jim_H
Jim_H's Avatar
I don't think he said that at all. He was just pointing out some obstacles to be dealt with.
Old 01-01-2006, 11:52 PM
mspiegle
mspiegle's Avatar
Originally Posted by Louie928
Heinrich,
I had the devek fans and rad on my 86.5 and never had a problem. I installed them to run full-time (probably a bad idea) and daily drove the car. I never had power problems as a result of this. I think I drove it like this for a few thousand miles.
Quick Reply: S4 cooling fans on an older car
