928 Forum 1978-1995
Sponsored by: 928 Specialists
Excessive Boost?
Old 01-01-2006, 12:46 PM
Garth S
Garth S's Avatar
Default Excessive Boost?
For your amusement ( if not a repost), this turbo was tweaked a little high . As one guy quipped, 'bring out the JB weld!'.
Old 01-01-2006, 01:02 PM
Jim_H
Jim_H's Avatar
That's crazy. In the 1st pick the wheels are still spinning. That's just nuts.
Old 01-01-2006, 02:05 PM
Steve Cattaneo
Steve Cattaneo's Avatar
Who said diesels can’t Handel boost
Old 01-01-2006, 02:49 PM
jeff jackson
jeff jackson's Avatar
GOOD GRIEF... Holy Mackeral...and all sorts of other expletives. I have seen lots of Blower explosions, heads blown off, etc. etc....But thats a first...Never seen a BLOCK blow apart and leave the crankcase, for THE MOON !!!
Old 01-01-2006, 03:51 PM
toofast928
toofast928's Avatar
Wow, and I was thinking of going to 9 psi............
Old 01-01-2006, 04:10 PM
FlyingDog
FlyingDog's Avatar
If he had just used 3.09s he could've created all the horsepower he needs without so much boost.
Old 01-01-2006, 04:15 PM
heinrich
928 Collector
heinrich's Avatar
Well I suppose you can blow anything up if you try hard enough Why is the cam at the bottom, and the cylinders at the top?
Old 01-01-2006, 04:20 PM
FlyingDog
FlyingDog's Avatar
The cam is on the side. It's a pushrod engine. The cylinders have seperate liners which are attached at the top.
Old 01-01-2006, 04:37 PM
SharkSkin
SharkSkin's Avatar
That's a classic "flathead" engine configuration. No moving parts in the head, the valve seats are in the block -- the valves move upward to open. You'll find the same configuration in a Briggs & Stratton lawnmower engine, unless yours is one of those newfangled Honda OHV motors.
Old 01-01-2006, 08:24 PM
Herr-Kuhn
Herr-Kuhn's Avatar
Probably staged turbos on that thing. Some of the pullers run staged turbos in excess of 200 psig. It is insane, the compressor discharge temps after such compression are into the hundreds with an S! But, it only has to run for what 30 seconds?
Old 01-01-2006, 08:35 PM
GlenL
GlenL's Avatar
But only to 42mph!
Old 01-02-2006, 01:37 AM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,079 Likes on 1,186 Posts
Funny you should bring up the Briggs & Stratton design
https://rennlist.com/forums/928-forum/36399-huntley-high-flow-intake.html
I should be having a beer with the ol'doctor tomorrow.
Old 01-02-2006, 04:39 AM
SharkSkin
SharkSkin's Avatar
https://rennlist.com/forums/showthread.php?t=36399
I guess the Doc isn't a big fan of Eaton/Autorotor setups.
Old 01-02-2006, 08:28 AM
special tool
special tool's Avatar
Noone.....ever. Diesels take more boost than anything.
Quick Reply: Excessive Boost?
