DR's X-pipe leads to new clutch!
Supercharged
DR says the GTS PP will be sifficient. I believe him. I will try to do a write up when I get to it. I didn't pay much attention to it, but I think with DR's X-pipe, I won't have to drop the exhaust. Is this right? Should be fun!
Rennlist Sponsor
Correct.
>Should be fun!
May not be "fun", but doing a 928 clutch job is the easiest I have ever done.
Correct.
>Should be fun!
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
![](http://www.928gt.com/images/928Specialists-COVER3-928GTcom.png)
Originally Posted by Mark
No $hit! We won't even discuss my recent replacement of my 951's clutch!
Suffice it to say..."Book" labor is THIRTY THREE HOURS!!!![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Eh, more like 11 IIRC.
I have the same question a Ernest! When a another 944 I had blew the clutch because I added NOS, I replaced it with 951 clutch and PP, and machined the flywheel at my buddy's shop in a weekend! At the most 18 hours. Ed M
928 Collector
Heh if I do a clutch, I guarantee you it takes 33 hours. I am extremely slow. But it will be better than perfect. I never make mistakes. Riiiiight
Range Master
Pepsie Lite
Pepsie Lite
I agree, I may take 33 hours to do a clutch, but that is 'cause I actually want to take 33 hours....Ernest, you sure they were not quoting you time on a transmission rebuild? Man, even a double hip replacement doesn't take 33 hours......
The 944 takes longer because you take, essentially, the whole rear drivedrain out of the car.
Duel disk clutch would require the timing gear change thing.
Originally Posted by DR
Matt,
>Andrew, just convert it to dual disk.
That is pretty ironic coming from a guy with this in his tag line ...
"1984 928 Euro S 5-speed: shifting challenged"
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Number of teeth changed?
Originally Posted by FlyingDog
I've always wondered about that... why can't you just use an S2 or S3 flywheel? They have all the LH sensors. Are the sensors different?
