the Burning question (928 car fires)
Unless I am mistaken it sure seems like our 928s burn more frequently than other cars. Is there a particular reason or group of reasons for this? Is the one or more common cause? Any particular upgrades or modifications to correct this?
A few days later.... Mr. insurance company, my car just caught on fire while I was warming it up in front of the house this morning. When can I get my check.
Now, there is an issue with the car losing half of the ignition, filling the cats with fuel and causing a fire. Porsche "fixed" this by cyl. temp. monitoring on the 89. Puts the car in 4cyl. mode to prevent a fire.
928 Collector
We had loosely talked before about retrofitting that 89 dealie to the earlier cars .... never went anywhere. Cat fires and I think more often, cracked old fuel lines.
Also the electrical system is unnecessarily complicated and many 928 electrical systems have been butchered over the years by people without the knowledge/resources to fix it right.
Every time I look behind my fuse panel and see miles of ALL BLACK wire I curse Porsche. What could they have been thinking?
Alan
Alan
Apart from the later cars, there are 18 channel aftermarket electrical system you can buy for 350.00 dollars and install yourself. No more problems. Even more abject usefullness on earlier cars with less "stuff".
That board under your feet as a passenger is preposterous. Heavy, overly complex, and totally confusuing.
Then you turn it over to find the 1000 black wires.
Today's cars are more complex, however. Mulitple boards like ours in different places, but with more engineering.
Buy and work on 928s, lease new cars. Thats my new motto. I don't have time to learn another car like I have learned the 928.
You gain about 10 inches of leg room without that board there in the passenger footwell.
And watch out for the condition of the power steering pressure hose down by the LHS exhaust header. It has been suggested that wrapping this section in something heat proof to prevent spraying oil on the exhaust would be easy to do, and would just produce a visible oil pool underneath, which should be noticed before too long. When mine started to leak, fortunately it just ran down the body and onto the ground without spraying.
jp 83 Euro S AT 49k
jp 83 Euro S AT 49k
It becomes less humungous when you factor in simply removing the entire thing and starting over. Keeping the plugs though, whenever you can and they are in good shape.
Isn't there an issue when updating the A/C to a non Freon ie hydrocarbon refrigerant? If you have a small leak in the A/C system this introduces a very flammable gas under the hood with the potential for a very serious fire/explosion. I guess the hydrocarbon refrigerent is a cheap alternative to replacing with a non flammable alternative, so beware of the risks if you are updating your A/C and are offered a cheaper alternative.
