PorKens Cam Timing Tool Rocks
I just bought one of PorKen's cam timing tool and checked the cams on my '89 GT. The right side was retarded about 2.3 degrees and the left was advanced 4 degrees! That's a difference of 12.6 degrees of crank rotation between the two sides! While I realize unless I index the cams according to the WSM I don't exactly know where they're set I was amazed at the difference between them. BTW, I think he only has a few sets left. ****** them up while you can.
Agreed on how well Ken's cam timing indicator tool works.
I adjusted my cams with the factory tools and WSM method to factory spec-big PIA. Seemingly minute adjustments between the cam gear and cam make a large change on the dial indicator.
When I checked the readings on Ken's tool after the factory type adjustment procedure, it showed my passenger side was .5 degrees retarded, and the drivers side was 1 degree advanced. Those two numbers are now my baselines for those cams for matching the factory 0 degree setup and making any changes later on. Much easier than pulling the cam covers to make any changes later on.
Jim
Jim
Keith,
No before/after dyno or g-tech, but the car pulls harder since the adjustment. I was way off before adjustment-I think it was close to 5 degrees advanced on one bank and about 5 retarded on the other. Much harder pull now, and boost starts building earlier in the rev range. As for a NA car, don't know, but it has to help.
Jim
Jim
I have the PorKen tool & adjustable timing conversion for the early cars... but I bought it right after changing the T-belt.
When it's time for a t-belt I'll go with HTD parts and make it adjustable.
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
Inventor
I have (2) 32V tools left, and (0) 16V conversions.
When I sell this last batch, I will have (in theory) come out even on the development costs.
I am still deciding whether to make any more. (I have to order at least 20 at a time from the laser cutter).
Here's the manual if you haven't seen it before: 32VCamSetup1_0.pdf (380Kb)
PM or email me for more details.
I thought the tool was only good for precisely relocating the cams from the WSM calibrated settings
borland
90' S4, Slate Metallic
Inventor
So far, I've only heard of the cams measuring +-1 cam degree when set with a dial indicator. 4 cam/8 crank degrees would be unusual, I would hazard.
Originally Posted by borland
Without calibrating the PorKen tool using the WSM procedure, how can you tell the two sides differ in adjustment?
Mine were off over 6 cam degrees, over 12.5 crank degrees, from each other. In reviewing my PO workorders I noticed at the last TB change that the mechanic had 'advanced cams 5 degrees for more HP'. But I don't see anything that shows the cam covers were removed to properly determine the advance and I haven't the faintest idea how he could have determined what 5 degrees advanced would have been. Thus I've always suspected the cams were out of sync, PorKen's tool confirmed it. Someday when I haven't anything better to do I'll index the cams, but until then I know I'm closer to spec than I was before thanks to Ken's awesome tool. Word to the wise, get one while you still can...
