The Twin Screw Thread
#3046
Hi, go to Kenne Bells web site, they still support the Auto Rotor Twin Screw as they worked together and ended up buying Auto Rotor and Improving on the Twin Screw design.
They service the units and sell the parts too.
http://kennebell.net/
Dave K
Dave K
#3048
I was thinking about it but now I may just upgrade the supercharger itself and install some larger injectors that it needs. Not sure why since it’s running so darn good!
#3049
Took a stop at the machine shop before heading down to Third Coast. Throttle housings are coming along. They are supposed to get the shafts and blades machined this week, and then start the process of boring the housings to match. Slow, but progress.....
#3051
doooooooood!! wow!
what size rotor are these mounted to?
#3054
I feel better
#3058
Its been forever in the making... literally forever. This assembly did not want to be born. Purchase orders sent to multiple shops, all had issues. This last one was issued in July and I just now have the parts.
Hoping to get a functional prototype using the printed parts put together tonight, just to verify everything is ready to go for machining the idle stabilizer block and the linkage pieces. I will get pictures posted of that here this week.
Progress!
Progress!
#3060
For those following at home....(correct me if im wrong) two throttle bodies on either side and the bypass valve inlet is on the bottom.
Looks beautiful.
Looks beautiful.
