I had my shop install a new idle control valve on my 1987 S4 automatic because the old one was not responding to input and was idling high all the time. Along with new idle control valve I had the injectors cleaned and balanced, and the throttle body cleaned. Now the car idles correctly when cold but still idle high when hot. I was told the temperature sensors are all working and the idle valve responses to input. What could be causing a hot high idle?
Tommy,
I had the same problem. I have a diagnostic tester made by John Speakes that will also reset the idle parameters in the computer. http://www.jdsporsche.com/jdsdiagtool.html. I am sure there are other tools out there that will work. No more problems in my case. Make sure you dont have any other vacuum leaks before doing this.
Thanks everyone for your help. The shop has tested the MAF and throttle switch and they were okay. Unfortunately diagnostic plug-in only started in MY 1988 so my 1987 cannot benefit from the fault code/resetting tool
Just try unhooking the cable from the throttle linkage on the side of the plenum.?
You said you have tested your throttle switch but if your cables arent adjusted correctly maybe the switch isnt being acivated. The srping in the trottle plate assembly is more than strong enough to close the throttle plate and activate the switc....unless the cables wont let it. I was just messing around with this today on Darriens 86.5 , a supercharger iinstall, the smallest adjustment can activate that switch. If it doesnt, your idle is high.
If you disconnect the linkage, try and keep some tension on it, or atleast be careful as with slack on the cable it may slip off the pulley underneath.
John - my car has 104K miles on it but the LH was replaced by the dealer at 70K. If I install the new EPROMs will I be able to perform the idle stablization loop to correct the idle? My shop will test the LH next.
The idle switch (not TPS) needs to be checked with an ohmmeter (pin 2 of LH)
or a test light, and NOT assumed to be functional because of a clicking sound.
Also, the idle valve signal (pin 33 of the LH) needs to be checked with a LED
test light (flashing) or an o-scope (square wave).
As mentioned, air leaks which bypass the idle valve will cause a high idle.
There's no need to use a diagnostic tool to "fix" an idle problem if the system
is functioning properly.
Tommy928
I had assumed that when the ISV was changed, then hoses etc which might leak in false air would also be attemded to.
You shouldn't need to run the diagnostic idle adaptation unless the MAF is badly aged. If it is aged too far, then it may never be able to get the idle stabilised.
Perhaps your shop can swap another known good MAF in there.
But, as said before check the other things that have been mentioned.
