Caliper/Rotor SHRANK!!???
Heinmo...rad my bruva. Me likie the twisty. Looks super swift with the curvatious lines of the moldingless S4. Unless you throw down for the Brembo's, it just may display a hint of riceage
Heinrich,
>The calipers and rotors .... they SHRANK!!?? DR, can you please advise??
If you think that's bad, Check this out....
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
Heinrich,
Were did you find 19" turbo twits? Solid spoke I imagine. I am almost done with the 18"s polished lip and darker centers. I find the big calipers look small with the 18's so they would be really lost with 19's. If you need I have a new set of 993TT big red rears for sale. You can have them machined to replace the fronts. They would look much better.
DAMN Dave that looks teeny. Why bother really?
..... Looks like you could just crawl through there to get your head behind the wheel to inspect it. And look at all that BLING, you have checkered flags on your tyres ... Oooooooooooooooh
... Seriously I love those humungous shoes
Anthony, I lucked-into them, private sale. Unobtainable, even on other porsche forums. Solid spoke, I think porsche OEM. So 993 rears, i think they are the same size as S4 fronts?
... Seriously I love those humungous shoes Anthony, I lucked-into them, private sale. Unobtainable, even on other porsche forums. Solid spoke, I think porsche OEM. So 993 rears, i think they are the same size as S4 fronts?
Heinrich,
Parking brakes :-)
Sure is easy to clean!
> And look at all that BLING, you have checkered flags on your tyres ... Oooooooooooooooh ...
I never noticed that before!
315/25-19s , oh yeah!!
BTW, get the part numbers off of the backside and I will see what the current cost is from Porsche.
Parking brakes :-)
The Medium S4's are the same caliper used in the rear of the 94 turbo they use a 44mm x 98 mm pad. The rear caliper from the 993TT is the same size as the front big red only uses a smaller pad.
Has anyone considered how to fit those new yellow breaks?
http://www.rennsportsystems.com/1-sf.html
Brake Performance increases from the various upgrades is dependent upon rotor diameter, thickness, caliper piston size, and brake pad area. The latter may be used to make a rough estimation of brake performance.
930 Turbo Pads are almost twice as large as Carrera Pads.
928 S4-type Pads are approximately 45% larger than 930 Pads.
Big Red/Turbo 3.6/C2 RSR Pads are approximately 100% larger than the 930 Pads.
There are several variations of Brembo Calipers that use the 928 S4-type pad. These have different size pistons and mounting options. Both Red and Black versions are available. Other colors are available at extra cost
Originally Posted by MrLexse
Heinrich,
Soon, its wheel time for me too. How have those 19"s been on the potholes? Tires? Would you change anything if you did it again ?
Keith THAT was one of the funnest reads to date
