Rear Tire Clearance question...
I'm having the bodyshop reshape the rear to flare it as much as possible... they talked me into keeping the overall 928 look. The rears are using a 19" X 10" wheel to balance the car's look better. Question is how close should I get from tire to inner fender considering the rear wheel steering without rubbing?
Rick... see picts.
Rick... see picts.
the beautiful thing about 928s, is that the action of the rear wheel only helps with clearance as you drive. (meaning, its worse case just sitting there)
i have less than a credit card clearance and no rubbing, using 11" wide 18" rims with 305x35s or 30s.
(or 315x30, or even 335s with my bat roll job)
MK
MK
Originally Posted by FlyingDog
You can buy the GTS rear quarters from Porsche... for about $2500 each. The only other option I know of is fiberglass like Louis Ott, Strosek, or Jacquemond.
Hammer
MK
MK
In my experience with widebodies and flares, many people tend to overlook the angle at which the rear wheel goes into the fender well. In a custom application, when the clearrance is even around the tire, it is the REAR of the rear tire that would rub first. I'm currently suffering from this on one of my cars, and it hasn't been fun dealing with it. Note that in stock form, there is plenty of clearance back there, but if the bodyshop is touching that area too, do make sure to keep more room in the back than on top.
...just my $0.02
Through out what you learned about other cars, the weisach and the 928 body shape, in the fender is different. if it rubs when you drive it, you didnt have the clearance to begin with, as many sharks tires are below the fender line, where you really want it just over the tire for most street applications.
the independant suspension allows for the wheel to go in as i goes up on a radius of the lower and upper unequal length control arms. the toe-in effect can give you a rub on the inside, or the movement can make you rub on the inside as well if you are too far in to begin with.
Ive set up 5 928s this way to use larger tires ,and none of them had a rubbing problem.
the other side that can be an issue is the alignment set up. generally most of the cars ive worked with have been at least 1.2degrees camber in the rear, and i rolled all of the fenders to start, so there was some massaging of the fender shape from the beginning
Mk
Mk
Originally Posted by TAREK
I don't mean to challenge you Mark, but it makes absolutely no sense to me!!!! I know many 928's that have a perfect stance when parked, but rub when driven. The rear wheels DO go IN the fender well on the road, otherwise the whole point of an independent suspension is moot...
...just my $0.02
...just my $0.02
Rick (and Mark K.)
Rick, it looks like those flares are gonna be great! I can't wait for the show later this winter.
Mark, Thanks for clearing up the fender rubbing issue. I was thinking that the W-axle would swing at the same angle as the links. You confirmed it. Also I saw your wheel size on the post above. so ignore that part of my PM. Thanks - Ruf
Hey Rick,
I have spacers on the rear that required a mild rolling of the rear fender. Actually it was a matter of grabbing and pulling the fender out slightly. My car sits pretty low in the back, with the widest portion of the tire up in the fender well. There is barely enough room to push my pinky between the sidewall and the inner fender in the rear. There's a roller coaster section on the back straight of one of our local tracks that I've bottomed out on a few times (bad line w/a passenger) and the tires have never rubbed.
I'm with Mark on this one, I think you can go pretty close without an issue. From the looks of your pics, I'd say you don't have anything to worry about.
Rick... see picts.
Rick... see picts.
Here is a pic of mine when it was all the way down for the test and another after the fender was blended in to match the shape of the body. Wheels are 12x17 and the tires 335.
https://rennlist.com/forums/attachme...id=89398&stc=1
https://rennlist.com/forums/attachme...id=89399&stc=1
Originally Posted by drnick
louis, that looks awesome
