928 Forum 1978-1995
Sponsored by: 928 Specialists
DIY mod to copper spark plugs to gain 22% increase in torque and fuel economy?!
Old 11-27-2005, 09:43 PM
  #31
SharkSkin
SharkSkin's Avatar
Originally Posted by DANdeMAN
SS, this is one hell of an Event producing device you have there. Patend pending I presume!?
Looks pretty close to the one I described but BIGGER.
Patent Pending of course. Will go into production as soon as I can figure out how to manufacture millions of teeny tiny stormtroopers economically. I am still seeking funding to R&D that aspect, because I'm sure that once that hurdle is overcome the "DeathPlug" will put all spark plug companies out of business. Please PayPal $$$.
Old 11-27-2005, 10:26 PM
  #32
heinrich
928 Collector
heinrich's Avatar
I thought it was called a MASS turbulator ....
Old 11-27-2005, 10:28 PM
  #33
heinrich
928 Collector
heinrich's Avatar
Not into mass turbulation myself, but hey, it takes all kinds and whatever floats your boat
Old 11-28-2005, 12:03 AM
  #34
AO
Supercharged
AO's Avatar
You guys are funny! Thank you for the good laughs...
Old 11-28-2005, 04:38 AM
  #35
Louie928
Louie928's Avatar
Originally Posted by Mark
I think this guy must be the same SOB that wakes me up at 4am by sending me the "Hot Stock Tips" to my FAX machine!!
I say we hunt him down and beat the sh%t out of him!!
Now, now. Calm down. Take a few deep breaths. Use some of these along with the insertion device to ease over life's little problems.
https://rennlist.com/forums/attachme...id=88747&stc=1
Old 11-28-2005, 11:46 AM
  #36
heinrich
928 Collector
heinrich's Avatar
Old 11-28-2005, 12:03 PM
  #37
klatinn
klatinn's Avatar
Hi everybody,
We at innovate are getting more and more calls from customers wanting to use our widebands to save gas. Just a few days ago a customer called that bought one after reading a magazine article. Though the only thing he knew about his car was that it has 6 wheels (spare and steering wheel included), but nevertheless wanted to use the wideband to lower his fuel consumption, and called to find out how.
This inspired me to come up with a new invention. As this invention does not fit into the current product lineup of innovate, I am offering it here for any forum member who wants to make a fortune in the automotive aftermarket. Licensing under the Gnu free public license (ask your nearest geek, he'll know). Different than other fuel saving devices offered (like fuel-line magnets, e-superchargers and so on), this device is 100% guaranteed to save between 5% and 50% of fuel (results vary with driving style), can be installed by any car owner in minutes, and does not affect drivetrain warranties.
I am calling it the 'Organic Thermodynamic Force Modulator, pat. pend.'.
Design/application description
With the engine off, depress the gas pedal by hand to it's full WOT position. Measure the distance between the back side of the pedal and the firewall or floorboard. Add 1" (25.4mm) to that measurement. Fabricate a piece of wood of that thickness (distance + 1") and securely fasten it to the firewall or floorboard behind the gas-pedal. Organically grown wood is used because it is a renewable resource.
Theory of operation
The increased angle of the throttle plate at full power forced by the device causes a vortex behind the trottle plate. This vortex causes the engine to use less of the precious air we all breathe. The EFI system, in it's attempt to maintain the same air-fuel-ratio, injects correspondingly less fuel. Different to other vortex generators mounted in the intake path, it reuses the vortex generating facilities already put into the car by the manufacturer. Other vortex generators (Turbolator et. al.) create a vortex where the axis is parallel to the intake path. This can throw the fuel droplets to the intake walls, where they stick and are not available for consumption. The device described here creates a vortex at 90 degrees to the intake path so that the fuel droplets will not stick. In some cases the device even allows to use a lower grade fuel for further savings. In addition the device dramatically lowers the danger of engine knock.
Marketing plan
This product can be sold on late night cable TV or ebay easily for $29.95 (+$6.95 S/H).
From a marketing standpoint one could offer a turbo version (made of teak or mahagony) and a n/a version (made of plywood).
The pro version (sold for 3 easy payments of $19.95) can even have an appropriately located microswitch that allows datalogging.
Regards,
Klaus
Old 11-28-2005, 12:05 PM
  #38
Tom. M
Deleted
Tom. M's Avatar
Originally Posted by David R. Hendrickson
Splitfires?
Haha...funny..cleaning the shop last week and ran across the splitfires that were in my old departed 84. Car wouldn't pass emissions so I pulled those put in the stock bosch ones..and new wires rotor etc....and passed with flying colors.. Don't know if the non pass was related to the plugs..but bet they were part of the problem.
I still have the full set of 8 if anyone wants them....
Later,
Tom
89GT
Old 11-28-2005, 12:20 PM
  #39
heinrich
928 Collector
heinrich's Avatar
Tom here is your golden opportunity to save BOOCOO BUCKS in gas. just use a dremel and cut little vortices into them. VOILA! The new finer electrodes will collect the unburnt gasoline already present in the air from all that smog from gas guzzling SUV's and burn it efficiently. You never have to fill up this way.
Old 11-28-2005, 12:29 PM
  #40
AO
Supercharged
AO's Avatar
Ok guys...
I've been trying to keep this one under wraps until the timing was right, and I think this is as good of time as any. Quantities are limited, so call today!
Old 11-28-2005, 12:35 PM
  #41
Rob Roy
On the Bandwagon
Rob Roy's Avatar
After seeing this thread, I decided to read the 9 pages of dribble that this idiot spewed forth in his/her previous thread.
What a waste of time.
Old 11-28-2005, 12:56 PM
  #42
Tony
Tony's Avatar
Originally Posted by Andrew Olson
A witch! A WITCH! Ban him... BAN HIM!
And how do we know he is a witch?
He's got a witch's nose! (He turned me into a newt!... I got better) BAN HIM! BAN HIM!
Ok... I thought I could have some fun with this post... but this troll isn't worth it and needs to be taken out. I already put him on my ignore list, but even his thread titles are a load of crap! Go play on RoadFly!
Randy... Smoke him!
That was good for my chuckle of the day
Bring out your dead....bring out your dead....
sjsj=LAG!
Old 11-28-2005, 12:57 PM
  #43
Flott Leben
Flott Leben's Avatar
klaatu barada nickto
"Klaatu Barada NECKTIE!"
Dave, I love "Army of Darkness."
Old 11-28-2005, 12:58 PM
  #44
Tony
Tony's Avatar
Originally Posted by Abby
This guy must be a member of the Wiggles....
What color does he wear? red blue yellow or purple!
Old 11-28-2005, 01:03 PM
  #45
CWO4Mann
CWO4Mann's Avatar
Something here tells me that we ALL have too much time on our hands now that winter has set in here in the Northern Hemisphere. This is positively the LAST time I will post in this thread! So there.
Cheers,
Quick Reply: DIY mod to copper spark plugs to gain 22% increase in torque and fuel economy?!
