Where do these go? Harness question
Administrator - "Tyson"
This is the front harness that goes to that multi pin plug in the right fender. I cannot find my notes telling me where they came from, nor can I find this info in the WSM (if you know where this is, that would be great)
![](http://members.rennlist.com/hacker_pschorr/connectorA.jpg)
![](http://members.rennlist.com/hacker_pschorr/connectorB.jpg)
![](http://members.rennlist.com/hacker_pschorr/connectorC.jpg)
Under the Lift
Connector C is main power and goes to the charge post. A & B look like grounds. Not sure where they go...what year car? The AC valve thingie would be the low pressure switch, but that's in front of the radiator.
Connector A & B both attach via the bolt that secures the grommet/bracket shown next to connector B in your pic. It's a 6mm that sits just behind and inboard of the TB vent to the air tube. The bolt screws down diagonally, in the direction of the crank.
