Engine won't rev
I have a 928S 1983 4speed Automatic that I baught from a guy in california with a deffective transmission. I changed the tranny with a used one and now I am facing an engine issue: the engine won't rev easily. It idle smooth and rund smooth even when I try to rev it. On the road, it's like if the throttle sets the rev: the more open is the throttle, the more rev I get. If go on full open throttle, it can do the 0-60 in ~7 seconds, which I think is the spec.
Here is what I have done so far:
- Checked and replaced all the 'rubbers' in and around the intake.
- played with the timing (I dont' have a timing lamp yet but played wit the timing a little bit at the time)
- Checked the cam timing
- disconnected the O2 sensor and forced the full throttle switch to ON
- Pushed on the AFM plate to simulate more air flow (and hopefully enrich the mixture).
- Opened a vacuum hose to let un-metered air in the intake (to lean the mixture)
- Changed the sparkplugs (that was last year, when the idle wasn't really smooth)
- Verified the resistance of the AFM and temperature sensors. The AFM resistances are within the values of the later AFM as per the workshop manual (i.e. twice the values of the previous generation of AFM). but the Temperature sensor on the AFM has a resistance value that corresponds to the previous generation according to the workshop manual... Can the workshop manual be wrong for that one?
Because I can have 0-60 in ~ 7 seconds, I don't think it can be fuel pressure or friction in the tranny.
The next things I will do will be to take the tranny down once more ($#%#@) and try the engine with no tranny (I have to change the torque converter seal anyway @#*&^@$#)
I will defenitely check the timing when I get a timing lamp in a couple of weeks.
I definitely need some help on where to look
. Is there a way to check if the air-fuel mixiture is good by using the O2 sensor? What kind of test can I do on the ECU?
Thank you in advance for your help.
Jeff
. Is there a way to check if the air-fuel mixiture is good by using the O2 sensor? What kind of test can I do on the ECU?Thank you in advance for your help.
Jeff
You're saying that you need to press down on the accelerator to open the throttle to make the car rev higher and you can do zero to sixty in 7 seconds. What am I missing here? Oh please, kind sir, help me understand what your problem is.
The problem is that the engine is not nervous. It is my first 928 so I can't compare with another 928, but I feel it is not normal that I need to depress the accelerator to 50% to rev the engine up to 3,000 RPM. On all the other cars I've had (includeing a 924S), I just slightly press the accelerator and the engine nervously rev up to 3,000 RPM; another slight push and it goes to 5,000 RPM. So the problem feels like if I had a bad timing or a the belt has just skipped a tooth. Because the engine doesn't rev easily it makes the automatic transmission shifting a bit erratic. I played with the timing with no success. I checke the cam marks at TDC and they are aligned with the marks on the cam case.
Is it possible that the cams are shifted by few degrees even if the marks are OK?
Can someone with a 4.7L engine and AFM tell me how much does the accelerator need to be depressed to reach 3,000 RPM or 4,000 RPM on neutral (e.g. 1/2" at the top of the accelerator).
Is there an easy way to check the air/fuel mixture? With the O2 sensor?
Any ideas?
Jeff
Supercharged
Jeff-
What you are describing sounds normal to me. It is a very linear relationship. If throttle response is slow I would suggest removing the cats, and maybe check ignition timing. Cams should be lined up, but it's possible one cam jumped a tooth, but pretty rare. Unfortunately, there no easy way to set cam timing on the 16v engines.
Remember this car has a V8 and gobs of torque. It was designed to be a GT, not a go-cart, so it will feel very different from a 924.
BTW, welcome to Rennlist.
My first suggestion is to find another 928 owner nearby so that you can drive each other's cars. This will quickly tell you if your car has a problem.
Best way to start is to give your location...
Originally Posted by Andrew Olson
Jeff-
Thanks for your help.
By the way, my wife starts to tell me that I shouldn't have baught this car (@#$@*&#) because I have been working on it for almost 2 years now (the transmission took most of my time), but I just love these 928s and would like to enjoy driving mine soon.
Jeff
I am in Fort Wayne, Indiana. I am willing to do a little drive during this Thanskgiving weekend if someone within ~100 miles has a 928 that I can compare with.
Jeff
Supercharged
Jeff as Wally (serious 928 Guru BTW,
) suggested, it would be good for you to compare your 928 to someone elses. Where are you located?
But from your last post, it sounds like your issue is not with how the engine revs on its own, but how it revs while driving (under load). Is this correct? Throttle position should have nothing to do with it as this is an arbitrary measure. I've not driven a 924, so I don't know what the gas pedal feels like in that car.
Does your car feel like it's shifting early? Maybe not revving to redline? If so, it could be a couple of things, but most likely the addition of a kickdown override switch will help liven up the performance. I've only had manuals, but I think it's just a matter of putting an inline switch connected to the leads on the kickdown switch under the gas pedal. 5-minute install - if that. Give it a tray and see if that improves things.
) suggested, it would be good for you to compare your 928 to someone elses. Where are you located?But from your last post, it sounds like your issue is not with how the engine revs on its own, but how it revs while driving (under load). Is this correct? Throttle position should have nothing to do with it as this is an arbitrary measure. I've not driven a 924, so I don't know what the gas pedal feels like in that car.
The tranmission doesn't up-shift unless I release the accelerator. There are 3 things that influence the shifting points: accelerator position, oil pressure (proportional to RPM) and speed. So when I accelerate, I have to presse on the accelerator a lot to get a decent acceleration; the engine doesn't reach the RPM it is supposed to for the accelerator position so oil pressure is too low for the transmission to shift up.
This is all from my understanding of this automatic transmission... And I agree that it will be very instructive if I could check with another 928.
Jeff
