Post DE report on Fuzion ZRi tires
#32
Yokohama S Drive are really nice tires, have them on a SL 600. Has anyone tried the General Exclaim's, they are very highly rated by Tire Rack and are even less expensive than the Fuzion's - $340 a set for 16" wheels.
#33
i drive a boxster rather than a 928, but have tried TONS of different tires on street / track over the last few years. my previous set was the bridgestone RE-01R. following those, to save some $$$, i decided to try the ZRi since it's so cheap. it really feels very similar to the RE-01R, which is a pretty high dollar tire. the grip on the ZRi's seems to be in the 0.95 territory for my car, whereas the RE-01R's were good for 1.01G. the ZRi's hold up well on the track and are reasonably comfy & quiet on the street. they last a pretty good while, too.
my lap times on a 1.41 mile track only went down by half a second with the ZRi's compared with the RE-01R. for the price difference of 120%, it's just not worth it to me to pay that much money for a half a second. i am now on my second set of the ZRi's.
BTW, those having issues with chunking are probably not running enough pressure. low pressure creates excessive heat. FYI, i run these at 38psi hot.
#35
Went to SITM 08 on these tires (2000 plus mile round trip) and they were fantastic.
#36
Chronic Tool Dropper
Mike V, what are your rim widths? Just curious... You are one size wider tire than I am with 7.5 and 9, and the fronts don't look like they could handle much more width. PS2's on mine.
#37
dr Bob,
My rims are the same width as yours. I was also worried about fit, but took a chance. They turned out fine to me anyway with only 10mm additional width. They are wearing fine (not in the middle as you would expect with too wide of a tire on too narrow of a rim).
#38
Mike, and Dr Bob,
If you check the manufactures recommendations and approved rim widths for tires you will see that you can run upto a 245 on a 7.5" rim,
I have a set of the same rims as Mike, and I have 245s on all 4 corners as it was all I could get at that far away place.
