928 Forum 1978-1995
Sponsored by: 928 Specialists
What does this button do?
Old Oct 13, 2005 | 07:12 PM
Glenferd's Avatar
Glenferd
Default What does this button do?
Today I discovered a small metal pushbutton under the dash. I have no idea what it does. Does anybody else have this? I'm not referring to the intense washer fluid button, it's lower than that. Hopefully the picture helps a little.[IMG][/IMG]
Old Oct 13, 2005 | 07:24 PM
BrianG's Avatar
BrianG
It's probably not stock......... I have a 1987 Euro (ROW) and this button is not present.
An easy way to determine this is to drop the parcel tray enough to see the wires and switch plug. Non-stock wiring is pretty obvious.
Old Oct 13, 2005 | 07:42 PM
Greggles's Avatar
Greggles
what happens when you push it?
My bet....anti theft kill switch.
Old Oct 13, 2005 | 07:45 PM
Ed Scherer's Avatar
Ed Scherer
Probably for a PO-installed device like an after-market alarm disabler, or maybe wired to a garage door opener stuck under the dash or something.
Or maybe an after-market ejection seat trigger.
Or, if it's push-on/push-off, maybe a PKS (parallel kickdown switch).
Old Oct 13, 2005 | 07:49 PM
Fabio421's Avatar
Fabio421
Man of many SIGs
Smoke Screen
Old Oct 13, 2005 | 07:59 PM
Glenferd's Avatar
Glenferd
I didn't notice anything happen when I pushed it. Although I didn't look in my rearview mirror
I'll have to try pushing it when my alarm is going off. That sounds like a good possibility.
I was actually installing a kickdown switch when I noticed it. I didn't see any other wires in that area, so I don't think it's another kickdown. Plus, it's not a push-on, push-off type button, it's just a push.
Maybe it's a nitro button that I never knew I had
Old Oct 13, 2005 | 08:20 PM
SharkSkin's Avatar
SharkSkin
Many aftermarket alarms have a button like this to disable the alarm when pushed at the same time you turn the ignition on. It's there in case the batteries in your keychain transmitter go out...
Old Oct 13, 2005 | 08:58 PM
Drewster67's Avatar
Drewster67
NOS ????
Old Oct 13, 2005 | 09:01 PM
Scott Turnbull's Avatar
Scott Turnbull
50 cals out the driving lights!
Old Oct 13, 2005 | 09:02 PM
CWO4Mann's Avatar
CWO4Mann
Was the car ever owned by a Florida drug smuggler like mine was back in the early 1980's? Might check with DEA on that "button". :-)
Old Oct 13, 2005 | 09:33 PM
Mongo's Avatar
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
Oil Slick. You bought the Spy Hunter car
Old Oct 13, 2005 | 09:35 PM
IcemanG17's Avatar
IcemanG17
Glen
Where does the wire go? My first thought was a kickdown bypass....but thats not it?
Old Oct 13, 2005 | 09:47 PM
rixter's Avatar
rixter
928 OB-Wan
alarm or fuel kill switch... though I have seen taillight kill switches there as well
Old Oct 13, 2005 | 09:59 PM
G Man's Avatar
G Man
Like Iceman said. Follow the wires to see where they lead to.
