928 Forum 1978-1995
Sponsored by: 928 Specialists
4spd AT upgrade?
Old Oct 14, 2005 | 02:03 PM
m21sniper's Avatar
m21sniper
Originally Posted by SharkSkin
I think m21sniper has a 4-speed auto in his early car, an '82 IIRC. I haven't seen him around in a few days, but maybe you could PM him and talk him into crawling underneath to get the # off the tranny.
Mine is an 83 bro, the 4spd A/T was stock in my ride(not sure about the high stall 2500+ RPM converter though, i suspect that's a PO modification). Sorry i couldn't help.
Old Oct 14, 2005 | 02:06 PM
m21sniper's Avatar
m21sniper
Originally Posted by G Man
I actually like the three speed in my 81 better than the 4 speed in the 84. I was considering switching them out before I sell the 81. Am I crazy?
Yeah, you're nuts IMO.
Old Oct 14, 2005 | 02:08 PM
heinrich's Avatar
heinrich
928 Collector
Default 1st Gear Starts
I've never understood why S4 AT owners don't flock to older trannies ('85/'86 and early '87) because of the fact that those start and shift down to 1st gear from "D". I've had both and it's like a whole different car. So, as I say, if I were into autos I'd be all over those. As well as the 2.54 and 2.73 Euro AT boxes.
Old Oct 14, 2005 | 02:09 PM
heinrich's Avatar
heinrich
928 Collector
GMan I'd happily trade you a 3spd box for your 4spd.
Old Oct 14, 2005 | 02:30 PM
SharkSkin's Avatar
SharkSkin
As to the first gear starts.... you could probably get this functionality by going to someone who knows MBZ trannies and have a little valve body work done.
Old Oct 14, 2005 | 03:01 PM
m21sniper's Avatar
m21sniper
I'm sure you could. Should just be a matter of changing the check valve spring pressures in the valve body.
Old Oct 14, 2005 | 04:07 PM
Bill Ball's Avatar
Bill Ball
Under the Lift
Hi H:
Of course, you know this - I just want to make sure nobody thinks you need to swap trannies to get 1st gear starts. Just pull the selector from D to 2 as you come to a stop and you get 1st gear from the line. The later AT drops into 1st below 6MPH. I start out with the selector in 2, at redline oor wherever I want, I move the handle to 3 briefly and back down to 2 for the shift to 2nd gear, etc. I like controlling the shift points by moving the handle, so leaving it in D and still getting 1st is not something I miss.
