CIS K- Jetronic on racecar problems
On a 79 with the mech fuel injection what would be the cause of this sympton?
Some background is in order first,
-The engine has been re and re'd for cleaning and checking. It is in a racecar so anything not needed has been removed .I left all the stuff for the fuel injection intact and have replaced all the vaccum lines and reconnected according to what info I could find in the factory service manual
- After getting the mixture and idle to a satisfactory setting , that is no hesitation from idle and starting ok. When i accelerate the engine and then close the throttle completely the engine will stall and be hard to start as if it is flooding. As i lean out the mixture the stalling is less severe but still there.
Did I get some vaccum lines wrong or is it a fuel pressure problem? Thanks for any input.
Darrin.
Darrin.
Have you checked item 21, the Vacuum Limiter?
I'll go over my lne connections again tomorrow, might have to get out the mityvac tool and check some stuff. It would help if I could find the website again that explains CIS operation.
D.
D.
Originally Posted by GlenL
A sticky vacuum limiter lets air bypass the throttle and will make it rev high.
Darrin, did you remove this device?
D.
D.
Dave, i didn't remove it but you can bet it will be the first thing i start checking out . Could be a wrong pick-up point i used for the vaccum.. there's definately enough of them!
D.
D.
