Engine mounts from 928 Motorsports
Hi to all, I recently purchased and fitted some 928 Motorsports engine mounts. Here's what I found, they give a good height when installed, when modified slightly you will never know that they are not genuine mounts.
The differences are that the two locating lugs or notches are different, on these to that of the genuine. So what I did was drill a 5 mm hole on the black metal piece that attaches to the engine block and this then locates the mount basically as well as the Porsche one. On the bottom I hacksawed my original lugs off and then drilled them slightly off centre and then knocked them on to the smaller lugs that come with the replacement.
You need to becareful when doing this that you don't get things out of alignment, I did line it up properly and things were fine. Now if you were to look from underneath you would never know that the mounts aren't genuine. I also have to do my other car soon. I would happily use these again, what is the feedback from the guys who use the Ford mounts? I would be interested.
Cheers Greg
Cheers Greg
Hi Shane, so are you saying that, the Ford mounts have the same sized lug on the bottom? i.e. the lug that locates the bottom of the mount and slightly sticks through the bottom of the crossmember.
Cheers Greg
Cheers Greg
I'm not an expert on motor mounts but the pin on the mount is to keep it from rotating. The size of the pin is not critical.
Yep
Cheers Greg
